FAQs & Guides: Above-ground pools
		___________________________________________
I'm updating the original FAQ, which dates back to 2006!
Accessories- Lights, ladders, steps and cleaners
Dark Buster Light
Automatic cleaner advice
A good discussion about automatic cleaners
Robo Kleen cleaners
AquaBot Pool Rover
Holding down wedding cake steps
more about weighing down steps
another weight discussion
Base and cove - Sand, concrete, foam and preformed pool
Happy bottom and preformed pool cove
Styrofoam or sand
Do we need Happy Bottom?
Coving and wall foam
Preformed pool cove
Plastic before the sand cove
Consumer report - check here before you buy
Buying an above ground pool
Doughboy or Esther Williams
Steel - Aluminum - Resin ?
Walls - Aluminum, galvanized or copper?
Filtration - Size, type and trouble shooting
How long to backwash?
Advice for buying a new pump
Hard plumbing
Air in a sand filter
What size pump and filter?
When to change the filter sand?
Cartridge or sand, a good discussion
Backwashing a sand filter
General pool advice
Draining a pool
Just an example of the wisdom that can be found here
Water loss from evaporation
Heating - Everything related to keeping your pool a little warmer
Solar Panels
Good advice about solar panels
More solar panel info
Solar covers
Solar panel troubleshooting
Installation - Tips and advice
Photos - Oval pool installation
Blocks, leveling and oval pools
The ongoing question, blocks or no blocks?
All of us installing an oval pool
Installing a center drain
Question about leveling
Leveling the ground
Building a pool with our help, good things to be learned here
Is deeper better?
Liners - Where to buy them and how to install them
Temperature and liner installation
Where to buy a liner
Installation pics and advice
Matt4x4 tips and advice for installing a liner
More places to buy liners
Another installation method that works well for deep ends
Some pics of what you don't want and how to fix
A few thoughts before you order your liner
Metal Frames and easy set pools
Easy set pros and cons
Intex frame pool
More good reading about portable pools
Repairs - Liners, walls and other stuff
Repair small hole in wall
Sometimes it's just this simple
Finding holes in a liner
Finding a hole and patching
Termites and liners
