Re: Weighing down Wedding Cake Steps ?
Hi guys....just an idea to weigh your steps down safely. We got 3 pieces of 3-4 inch pvc capped off one end w/ pvc cleaner and adhesive. Then we filled the tubes with driveway rock and capped off the other end. THis makes for a clean, easy way to weigh down the front end. Easy to remove.....just make sure you glue the ends on well. The rails that you attach to wedding cake steps help hold down the back end, if you need more help there, make a few more and drill small holes through the top part of the back opening and concoct a way to hang a few more. There is a few pix on this site of someone who had done that. Just an FYI.. hope this helps.
30' Esther Williams Classic Granite
Installed july 2006
