Leveling stage here - ugh..My pool is only an 18' Intex, BUT I'm in North Carolina (beyond red clay, we're talking bricks.) and I'm doing it by hand in a yard with a major slope - had to dig 2' at highest level. Prayers of all denominations accepted!!
I have been spending the past few nights outside with my laser level as that's the only time I can see the beam. Are most of them visible during the day? Mine's only about 6 mos. old and wasn't a cheapie either, I'm bummed I can't get it to work outside during the day.
So, after reading some different threads here on leveling, I've come to the conclusion that if I want to work during the day (might be nice), I will need to use a water level. Someone was kind enough to post a few links explaining their use and I get the idea, I'm just unsure of how to use one to level ground. Do I pound in stakes all around the perimeter, measure off a hatch-mark on one stake and then compare this to a similar hatch-mark on all the other posts?
How do most people actually use a water level for this application?
Thanks,
Amy
PS I have several different lengths of carpenter's levels and a string level, which is what I started out using, but in double-checking my work with the laser I found these to be very inaccurate. Are all string levels as useless as mine appears to be?! I was off by up to 2" (according to my laser) in several areas after my string level told me I was okie-dokie.
Sounds like you got a very important job done with a water level, sometimes you just can't improve on simplicity - I'm sure I can make one work for me and my lil Intex after the story you told!!
Wouldn't be such a problem if every last bit of meager topsoil that we have here weren't graded away on every building site out there. And everyone wonders why it's so hard to grow grass
