Re: aluminum walls vs galvanized/copper wall
The first step would be to find a reputable dealer that has been in business for some time and stands behind their products. You should run, not walk away from one that tells you to buy a cheapie because all of them will rot soon. Check with the Better Business Bureau in the areas you will be shopping. If online, go to the BBB Online AND find out if the company has a brick and mortar real world business as well. Talk to others with pools to find out about theirs and satisfaction levels with brands and dealers.
You get what you pay for - do not go with the cheapest you can find, you will be sorry. If you do your research, you will see that there are many with warranties that give you a pretty good idea what the mfg expects for the life expectancy with normal wear and tear - they don't want to pay or reimburse you - so if the product is crap, then it probably won't be well warranted. Areas that rust first will probably be those that are in contact with moisture most, your bottom rail and base plates, service panel/skimmer/returns, top rails and/or uprights/caps. Look for materials in those parts that are guaranteed or give good detail about corrossion prevention or corrossion free (aluminum, special coatings, resin, stainless steel) Anything less than probably a 30 yr warranty should be avoided like the plague - try for a 40 yr or more, even lifetime if possible (more spendy) or go for a big Splash Pool brand, they are really tough soft sided that can remain up year round in all climates (not very attractive though) As the guys here will tell you, good planning, VERY good ground prep and proper chemical maintc go a long way towards extending the life of your pool.
If you only want the pool for a few years, then its an awful lot of work for just a few years enjoyment, even for a cheapie.
