I had to go out of town on business for a week.
I can't seem to get a reading on Calcium Hardness...
When I do the test according to the instructions in the Taylor K-2006C, the sample turns red, but never turns blue as I add the R-0012; it just gets more washed-out pink...?
What is a typical number of Reagent drops for color change?
Without a good number to plug in for Calcium Hardness, I'm not sure how to deal with any of the other numbers. I have a little bit of scaling (white ring) on the tile at the water-line, but not bad. I'm doing the test exactly in accordance with the instructions with the kit. Is there something I can do differently, or is there a number I can plug in as an assumption?
When I tested before my trip, my PH was over 8 and my Alkalinity was at 210ppm.
Over the next day I added a full gallon of Muriatic Acid, but then had to leave for my trip.
Today I tested again and came up with very similar numbers. Here's the comparison:
First test:
Chlorine = 0.00
PH = 8+ (10 drops to 7.4)
AK = 210
Couldn't get a reading on Calcium Hardness - went from Red to Pink, but never Blue or Purple
CYA = Off the scale above 100ppm
Added a gallon of Muriatic Acid and Shocked a couple of days later (Shocking w/1lb of Calcium Hypochlorite once a week at night just to keep water sanitized), then was away for a week. Tested today when I got back and here's what I found:
Chlorine = 0.0
PH = 8 (7 drops to 7.4)
AK = 200
Couldn't get a reading for Calcium Hardness - went from Red to Pink
CYA off the scale above 100 (took the 50/50 mix of pool water and R-0013 reagent down to 7ml and added 7ml of Distilled Water - 2 parts Distilled Water + 1 part Pool Water + 1 part Reagent = about 65ppm on the scale)
Still have the brown stains.
Please give me a starting point. What needs to happen first?
I only get to concentrate on this in spurts so I need to take it step-by-step.
Thanks,
Sam
