Using bleach alone is fine; you just have to manually add enough stabilizer to maintain good levels (probably, 40+ ppm).
Adding it via the skimmer is good, SO long as you have ZERO other chemicals anywhere in your system. Adding chlorine that way, can help avoid certain filter problems, since you regularly super-super-chlorinate your filter.
