1. If you have the Phos-Free, go ahead and put it in.
2. Retest phosphates in BOTH the pool AND your fill water. To manage phosphates in a pool, you need to figure out how they are entering.
3. Tell me your pool specs, so I can stick it in your signature -- it's easier to answer with that info in place. (Size, shape, surface, pump make/model, filter type/make/model, other equipment)
4. Run your pump 24/7 if you're not already doing so.
5. Don't buy more PhosFree. Orenda's PR-10000 is cheaper, on a ppm removed basis, though it clouds the pool. Kem-Tek's product is cheaper than Phos-Free, though not as cheap at the Orenda product, but doesn't cloud your pool. You'll have to find the Orenda product via Google, and you'll need to buy a clarifier to use with. I'll post links to Kem-Tek below. However, I'd get the testing done before deciding to buy more.
Kem-Tek 265-6 Pool and Spa Phosphate Remover, 1 Qt ($16.50 on May 12, 2014)
(1 quart will remove 2,000 ppm PO4 from 10,000 gallons.)
Natural Chemistry 5221 Phos Free Pool Cleaner, 3-Liter ($19.80 on May 12, 2014)
(3 liters will remove 1,800 ppm from 10,000 gallons.)
Clarifier (needed if you purchase Orenda PR-10000)
Kem-Tek Pool and Spa Ultra Clarifier
GLB Clear Blue
