Results 1 to 10 of 11
Thread: Stubborn algae and Frustrated Pool Owner
    Jul 2012
    North Carolina
    Default Re: Stubborn algae and Frustrated Pool Owner
    Thanks; will explore clarifier but I just added flocculant today to see if I could sink some stuff.
    I posted my pool details (pump and filter type, etc) to the google docs pool chart. I added an 'n' to my user name by mistake. Hence, you should have a prior entry from thomaso and an entry today from thomason.
    20x40 30K gal concrete rectangle IG pool; bleach; Tagelus sand filter; pump?; attached spa; K2006; net-dev
    10'x40' rectangle 30Kgal IG pool; Hand fed granular ; Don't know sand filter; 1.5 hp switch less pump; 24 currentlyhrs; Test strip for FC, Ph, and alkalinity. My pool pro tested for CYA last week.; utility water; summer: ; winter: ; iPhone; PF:4
    Quote Originally Posted by Thomaso View Post
    No clarifier for you, then, for at least a week.
    Jul 2012
    North Carolina
    Thank you. What do I do to get bumped to full membership permissions?
    Becoming a subscriber will allow you to post without having to go through the moderation queue first. You can find the link in my signature if you are interested in subscribing.
    Jul 2012
    North Carolina
    Received my Taylor test kit. The powder for the chlorine test did not arrive with the measuring "dipper". Can anyone tell me approx volume of the two dippers one uses to conduct the FAS DPD test? Looked on the video to be 1/4 to 1/2 a teaspoon. Thanks.
    Ph below 6.8 yesterday; added four pounds borax. Up to about 7 today. Will add more borax today.
    CYA: 50 (no more di or tri chlor)
    FC: between 5 and 10 on the test strip and appears to hold well during day.
    TA: about 40 (only test strip test ).
    I want to shock tonight; I estimate I need to bring FC to 20 ppm, which would be approx. 4.1 gallons of bleach (6%)
    Does this sound right?
    Thank you
    You only need enough powder to change color -- it doesn't even have to be a dipper full.
    BUT, the dipper quantity is MUCH less than 1/8 teaspoon. If you have some dry popsticks, and can whittle that down to about 1/4" wide, and then dip out enough to cover the tip of the stick, that should be more than enough.
    However, you should call an request a new bottle. That dipper is a fairly critical item.
    Regarding bleach dose: with a 30K gallon pool, your PF is 4, so each gallon of 6% bleach will add about 2 ppm. 10 gallons will add 20 ppm.
  1. New pool owner getting frustrated with costs
    By jaff50 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-22-2012, 08:32 PM
  2. Frustrated with Algae
    By thorn138 in forum Dealing with Algae & Slime
    Last Post: 05-21-2012, 09:21 PM
  3. Re: New pool owner with algae
    By rwhitsel in forum Dealing with Algae & Slime
    Last Post: 06-21-2011, 06:50 PM
  4. Frustrated with algae and chlorine
    By mnhwinn in forum Dealing with Algae & Slime
    Last Post: 07-31-2010, 03:34 PM
  5. Stubborn algae - Am I getting it yet?
    By PoolInMich in forum Dealing with Algae & Slime
    Last Post: 08-16-2006, 01:21 PM
