Results 1 to 10 of 23
Thread: Low Chlorine Problems
    Jul 2012
    Nebraska
    Default Re: Low Chlorine Problems
    Readings this morning:
    Fcl:4.54
    Tcl:5.62
    PH:7.3
    Alk:182
    Added another 1/2 box borax & 3 more Gallons of 6% Walmart bleach
    People look at you funny when you stroll through the store with 12 gallons of bleach & 3 boxes of borax in your cart. Either I'm a serious laundry man, or making some kind of terrorist concoctions
    You really need to bite the bullet and order a good kit --- Taylor K-2006. With a CYA level that is through the roof like yours, you will have to run extremely high chlorine levels (per the Best Guess Chlorine Chart in Ben's sig above). The HTH 6-Way kit and an OTO kit only measure chlorine to 5 and aren't going to help you.
    You did the right thing turning off the chlorinator but you are not adding big enough doses of bleach to accomplish anything since the CYA is so high. In your pool, each gallon (4 qts.) of 6% bleach will add just under 4ppm of chlorine. As you can see from the Best Guess Chart, your shock level is going to be around 25ppm, so the 3 gallons you added is not taking it high enough. Keep adding bleach every time you test and get back to 25ppm. Continue to do so until you can go from sundown one evening to within 2 hours of sunrise the next morning without losing more than 1ppm of chlorine and the water is clear. Then, keep it high for one additional day. After that, you can let the chlorine drift down but must always keep it between 8-15 ALL the time or you'll constantly be fighting algae. No more trichlor pucks nor any type of dichlor shock powder in this pool!
    Your pH is fine where it is so don't worry about more Borax at this point.
    Order the good kit. In this pool, it really isn't an optional item but a critical one or else you'll have a very difficult time managing this pool.
    Hope this helps. Good luck.
    Quote Originally Posted by nscclukas View Post
    My wife just cracked up, when I read this to her. (She's helping with some forum stuff right now, and is in the office with me.) She -- having been sent to the store on a MISSION by me -- commented, "He should try checking out when you bought the entire stock of 24 boxes of borax from a single store!"
    Jul 2012
    Nebraska
    Maybe I'm wrong? But I was thinking on 16,000 gallon pool 1 gallon Cl would raise 8ppm. We just recently bought the Lamotte Color Q 7 digital test kit. It is a liquid test kit, works great, no more guessing at colors, it gives you a # to go by. The mother in-law loves it, she didn't bother to check her readings before very often because it was always a guess what the color was. She just took samples to town & let the pool store tell her what she needed. For 20+ years, imagine how much $ she dumped into the pool. The local pool store will probably go out of business now that I've banned her from going there
    One gallon of 6% bleach in this pool would add about 3.8ppm of chlorine.
    I'm not familiar with that kit or how high of chlorine readings it can read so I can't comment on that. Someone else may know more about its capabilities and limitations.
    Jul 2012
    Nebraska
    Not sure if this should be under chlorine or algae?
    I'm still fighting to get my chlorine levels to stay high. It's a real battle, been checking 3 times a day & making slow progress. I have put in 20 gallons of 6% bleach, after filling the trash can with empty bottles, I decided to go to Menards & get the 15% LC, & have put in 10 gallons of that, thus far.
    This morning readings:
    Fcl:3.57
    Tcl:6.8
    PH:7.1
    Any ideas on how to kill this algae? I have scrubbed last two evenings Should I vacuum? Can't see the bottom of the pool, 3 feet at best. I have had it on filter continuously. How about backwashing? I have a couple times for a couple minutes, do I need to backwash till foamy bubbles are done? Pressure hasn't been high on gauge. Just wondering if I'm doing things right?
    If you want to know how much more chlorine it will take, you can get an estimate by doing a chlorine demand test:
    Bucket-testing-for-chlorine-demand
    But do NOT back off while you are checking: with algae, either YOU are winning, or THE ALGAE is winning. There is no 'coasting'; when you coast for a day or two, the algae will recover, and you are likely to lose 100% of any ground you've gained!
    By the way, you NEED TO GET A TESTKIT. Your FC=3.57 ppm result tells me you are using a somewhat bogus digital reader, which in turn tells me, that you don't know -- reliably -- what's in your pool
    [CORRECTION from ORIGINAL VERSION: The Lamotte Color Q is considerably better than the digital strip readers, which also produce 2 decimal point results. But the evidence still is that the unit's fundamental accuracy comes nowhere close to 2 decimal points, and does not approach the accuracy of titration methods, like the Taylor K200x series. In addition, there's an intrinsic problem with colorimetric methods for calcium and alkalinity: such methods are inherently logarithmic in progression, rather than linear like titration. Thus, color methods become more and more imprecise as the value increases. So the Color Q may be MORE precise than the K2006 for FC=0.1, but MUCH less precise for FC=10 or CH = 400. Unfortunately, this decreasing precision is masked the digital conversion process, which pump out multi-decimal results, even when the unit can barely distinguish 400 ppm CH from 500 ppm CH!]
    Please go get a cheap OTO kit, if nothing else . . . and then dose with bleach till you reach DARK yellow, or orange-tinted yellow.
    Ben
    + Get a cheap OTO (yellow drops) / phenol test kit, or if available at YOUR Walmart (check availability), get the HTH 6-way DROPS test kit, which is compatible with the Taylor K2006. Test the pool as soon and you can, and post the results. If you get the 6-way kit, ALSO test the water you FILL the pool with, especially if it's a well, and post THOSE results as well. (The HTH is the best available kit you're likely to find locally, but it's not the K-2006. It can only provide rough measurements chlorine levels above 5 ppm, and it measures "TOTAL" hardness, rather than "CALCIUM" hardness, which is not ideal.)
    + Having a good test kit makes pool care easier for EVERYONE. A good test kit means a kit that can test chlorine from 0 - 25 ppm, pH, alkalinity, calcium hardness, and stabilizer with reasonable accuracy. Test strips (AKA 'guess-strips' ) do NOT meet this standard. Some pool store testing is accurate; most is not. The ONLY way you'll know whether your pool store is accurate or bogus, is by testing accurately your own self. On the other hand, pool store 'computer' dosing recommendations are NEVER trustworthy -- ignore them. They are designed to sell more chemicals than you need, and WILL cause many pool problems.
    + We recommend the Taylor K-2006 test kit, which meets the requirements above, for many reasons. The HTH 6-way drops kit is a great starter kit, and is compatible with the K2006 (it's made by Taylor). There are a few alternatives; for example Lamotte makes an FAS-DPD kit that's OK -- but it costs 3x as much. But, we're not aware of any test that is better, and since we are all familiar with the K-2006 (and can help you with it) we recommend it exclusively ( Test kit info page )
    One caution for the 2012 season: Amazon does not stock the kits directly. So when buying at Amazon, Amato is our current preferred seller. However, they often don't list enough stock to last the whole day, so try order mid-morning. You should expect a delivered cost under $60 for the K2006A and under $95 for the K2006C. If you can't find that, wait a day.
    + Here are links to the kits we recommend (you can check local availability on the HTH kit, using the Walmart link):
    HTH 6-Way Test Kit @ Walmart
    Taylor K2006A (3/4 oz bottles) @ Amazon
    Taylor K2006C (2 oz bottles) @ Amazon
    Ben,
    Although I know nothing about them -- maybe you do --- this member has a Lamotte Color Q 7 digital test kit.
    nscclukas,
    The pH of 6.8 is too low. You should use some 20 Mule Team Borax (laundry aisle at Walmart) to bump it up to between 7.2-7.8.
  1. I'm back! Problems with chlorine and CYA
    By JeremyBlake in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-01-2013, 01:18 PM
  2. Chlorine Problems
    By acmtn in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-01-2006, 04:32 PM
  3. chlorine conversion...problems!
    By mypoolstinks in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-19-2006, 09:55 AM
  4. trying to switch to chlorine, having major problems!!
    By mypoolstinks in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-13-2006, 11:29 AM
  5. Chlorine Bleach Problems
    By MJKAST in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-10-2006, 02:38 PM
