Re: New to Forum
Ben,
I got the stabilizer today and made a slurry with hot water and the 4 lb jug and added to the pool. I hope you meant add 4 pounds at once. I'm reading the posts and according to the stabilizer label in my pool 4 lbs would get me to approximately 100ppm.I'm seeing alot of posts with larger pools at 40-50. I also added 182 oz of 6 % bleach because I was at zero tonight. From a few other pool folks suggestions I was only getting the chlorine up to 4.6 and not shock level . Janet said to use 2.6 gallons each time to get the level up.Let me know your thoughts.Pool is still light green. Thanks
24' round 13,500 gal AG vinyl pool; Haywood sand filter 1 hp s180t; ; HTH 6 Way OTO Drops; NW NJ
