16'x32' oval 15K gal IG vinyl pool; liquid chlorine; Hayward cartridge filter; Hayward 3/4 hp pump; 3/5/2012hrs; Taylor 2006c; utility water; summer: none; winter: vinyl / water bags; ; PF:8
So I tested my water this morning and my ph went from 7.8 down to 7.2 overnight. I did not add any acid or anything else to the water. What would cause the ph to drop like that????
Did your chlorine also drop? When chlorine is used up, the end product is acidic.
Yes, I dumped in 7 gallons of bleach at 8 PM and tested the water shortly after. I finally had a high chlorine reading. At 11 PM I retested and the chlorine was at 0 and ph was at 7.8 or so. This morning I tested the water, and chlorine was still 0 but ph had dropped to 7.2.
My plan is to put 7 more gallons in tonight at 7 PM, and then re-test at 11 PM to see if it held or not. If it dropped again, I will reapply 7 more gallons of bleach. I am trying to break this ammonia or bacterial trap I am in. I was just wondering about this ph drop I had and how I should handle it in the middle of this trap I am in.
At 7:30 PM I added 6 gallons of bleach, chlorine readings were very high. I have retested every half hour since then and the chlorine seems to be holding. The ph however is dropping. It is at 6.8 now at 9:45 PM. Should I address this or should I just stay the course and keep the pool in shock mode?
If you have some borax, I'd go ahead and add a box. It's not a crisis, but you don't want to leave the pH below 7.0 indefinitely.
So after testing the pool at 11:30 PM last night, I was showing a reading above 5 ppm (as high as my test allows) but it was not as yellow as when 6 gallons of bleach was added at 7:30 PM. I added another 6 gallons of bleach. At 6 AM this morning, I tested and re-added 6 more gallons of bleach. Ph seems to be spiking when chlorine is added, as expected, and settles in at 7.2 hours later. Water is still cloudy, though.
I think I have turned the corner in my battle with whatever is causing my chlorine demand. Now I need a test kit that reads higher than 5 ppm chlorine. Does the 6 way HTH kit from Walmart read that high? I can get one today, otherwise I will order one from Amazon.
