Results 1 to 10 of 25
Thread: Is stabilizer necessary?
    Virginia
    Default Re: Is stabilizer necessary?
    Thanks Dave. That information is helpful. So bottom line, I should stick with the CYA levels recommended by the manufacturer of my SWG?
    Some info for reference.....
    One reason this topic caught my attention is my personal experience over the past several years dealing with algae in my pool (my pool was installed in the spring of 2004 and it's the only pool I've ever owned). It seems despite keeping CYA in the 60-80 range, FC 5-7, and PH 7.5-7.6, the liner would keep getting slick (start of an algae breakout?) and I would have to shock and brush the pool frequently. Based on a recommendation a few years ago, I started using borax (maintained at 40-50) and polyquat 60 (I add a maintenance dose of 8 oz per week). Since doing this in combination of shocking every couple of weeks, I no longer have an issue with a slick liner. However, I do still get some visible algae in grooves and crevices (such as where the liner meets the steps and behind the trim around the pool light; possibly due to poor circulation in those areas?) which I'll brush out before my regular shock treatment.
    I'm tempted to discontinue the polyquat 60 to see what happens. That would save me a couple hundred dollars a season, but I'm hesitate to mess with what's currently working well for me. Except for the addition of polyquat 60 and Jack's Magic Purple Stuff (since using this I have no more staining issues which I'm told is a side effect of the SWG), I pretty much follow the BBB method.
    BTW, except for a few spring openings when I was using a mesh cover over the winter (I use a solid cover now), my pool have never been green (during the season it's always clear).
    Virginia
    So not the same Richard, that makes much more sense.
    While you were posting, I was editing my post. Any comments on the info I've added?
    Thanks.
    Go ahead and try it without the Polyquat and just be diligent about keeping up with your chemistry. You can always go back to using it if you decide you need to. I never use any Polyquat, not even when closing my pool. I'm consistent about my chemistry and don't really need it. What I don't have to spend on that, I can use to buy something else like maybe dog food! My 3 golden retrievers go through LOTS of dog food!
    Virginia
    Thanks for the response. When I'm feeling brave and ready to experiment (lol), I'll give it a shot.
    The article you reference is using ORP controllers to monitor the redox potential of the water (and not directly monitoring FC levels) and using a liquid chlorine injection system. First fact, CYA disrupts ORP controllers so systems that use then do not use CYA (or use very reduced levels). Second, his system has a pretty much constant chlorine 'drip" going into the pool. This is how many commercial systems are run out of necessity but it is not necessisarily the best way. I have also worked on a commercial install that used peristaltic dosing pumps for both liquid chlorine and acid for pH control but did not have any electronic control. The 2 pools and two spas at this installation were tested 3 times a day and the dosing pumps adjusted if needed. However, once they were set up they needed very little adjustment to keep everything where it was supposed to be.
    The info he references in the article (including teh one from Kent Williams) are mostly from those with connections to ORP controller manufacturers so it is in their best interest to say that CYA is NOT beneficial because when you use ORP control it is a problem and makes the system malfunction.
    Virginia
    Thanks. I appreciate the clarification.
    Quote Originally Posted by JimK View Post
    Sounds like a circulation problem, although I have another suspicion as to what might be going on and adding to the problem. A few questions:
    How many hours do you run the pump a day?
    One speed or two speed pump?
    How many returns, skimmers, etc?
    Which cell are you using with your Aquarite, T-3, T-9, or T-15?
    What output percentage is the Aquarite normally set on?
    What are you using to test the water and how often do you test?
    How often do you brush your pool?
    Do you have an automatic pool cleaner? If so which one and how often do you run it?
    How often do you vacuum your pool?
    How often do you backwash the filter and do you retest the water after topping it off and adjust chemical levels again if needed?
    What are you shocking with (the SWCG or with manual addition of a chemical) and it is after or before backwashing?
    FWIW, you should run your CYA at 80 ppm with the AquaRite. I indirectly helps with pH control since you can run the cell at a lower output to maintain the same FC which means less production of hydrogen bubbles in the cell which means less aeration of the water which means less outgassing of CO2 and outgassing of CO2 is the main cause of pH rise in a pool.
    Using both borate at 50 ppm and polyquat is probably overkill and personally I am a big fan of borate and have actively promoted its use for several years now.
    Getting back to your pool problem...IF you have pool circulation in some areas then algae might start growing even if you are doing everything right. Running with no CYA is NOT going to solve the problem and could even make it worse. The best way to solve the problem is to brush the pool on a regular basis. You want to brush down the sides of the pool all the way around. This sets up currents that 'stir up' the water in the pool and help eliminate dead spots. Most people do not brush their pools often enough, many do not brush the entire pool but only areas that have algae or dirt, and some pools just need more brushing than others to keep them clean.
    Virginia
    It's really not much of a problem, mainly a minor annoyance, as I only see algae in a couple small spots in crevices where it's likely water circulation isn't great. The rest of the pool stays clean, clear and free of algae.
    14 hrs a day (it's on a timer; runs from 7am to 9pm)
    Single speed pump (Hayward Superpump; not sure of the HP rating but I'll check tonight)
    2 skimmers, 3 returns (one of which is in the steps)
    T-15
    Normally 40-50%
    For PH, TA, CYA I use a Taylor test kit/reagents. For Chlorine, I use the Taylor DPD powder test kit. For borates I use LaMotte test strips. This year I just started using the test strips recommended here to test salt level (matches almost exactly the reading I'm getting on my SWG). After everything is balanced and up and running, I usually test PH and Free Chlorine every other day (if I notice a significant change or something going on, then I'll test everyday or more often until back on track). TA usually gets tested about every 10 days to 2 weeks (again, if needed, I'll adjust and test more frequently). I'll test CYA, borates, and salt if the salt level reading on the SWG drops. For some reason I feel like I'm forgetting something here (I'm at work right now and trying to do this from memory). I'll check my records (I keep a pool calendar/diary) when I get home to see if I forgot something.
    Once up and running/balanced, not very often as it doesn't seem to need it. Like I mentioned before, since using borates and Polyquat 60 I never have a slick liner or visible algae (except in a couple crevices as mentioned above).
    Yes. Up until this year, I was using a Hayward Viper (uses a booster pump). The Viper died again so this season I replaced it with a Polaris 280 (also uses a booster pump; works great so far, better than the Viper IMO). I would say on average I run it every other day (I like to keep my pool clean and pretty)
    I manually vaccuum for spring cleanup, then infrequently during the season as the automatic cleaner does a good job keeping it clean.
    Whenever the pressure rises 10lbs above "clean" pressure (clean pressure is typically 10lbs, so when it gets close to 20lbs I'll backwash). Usually during the entire season I only have to backwash once or twice (I'm using a Hayward DE6020 DE filter).
    Since replacing the salt cell in 2006, I stopped using the SWG to shock (ie - set to "superchlorinate"). I figured manually shocking with Calcium Hypochlorite (68% is what I use. I'll have to double check the chemical name when I get home, but I believe this is correct) I could extend the life of the new cell. Our pool gets light use (only two of us in the household) and I find shocking every 2 weeks seems sufficient (unless we get a very heavy rain at which time I'll go ahead and shock again). There's no correlation between when I backwash and when I shock.
    Thanks for your help and info.
    Overall my current routine works very well, I'm just wondering if I'm overdoing it with the algae control and perhaps can save some money.
  1. Stabilizer
    By cooper in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2011, 10:26 PM
  2. Stabilizer
    By Sue225 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-12-2011, 01:22 AM
  3. Stabilizer
    By Calcutta in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-26-2008, 11:31 PM
  4. Stabilizer
    By mackeeg in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-17-2007, 01:16 PM
  5. HTH Stabilizer
    By let_her_flicker in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-20-2006, 07:57 AM
