Results 1 to 10 of 10
Thread: Stabilizer
    Default Stabilizer
    Do you need stabilizer in your pool every year? Do you need it at all?
    Indiana.
    Default Re: Stabilizer
    It keeps the sun from depleting your chlorine during the day. Maintain it between 30 and 50ppm and you will be fine. What you need every year depends on how much is left in the spring.
    We have had your pool 3 years and I don't think we have ever put it in. Our neighbor just got a pool and at pool school they told him to put in 2 pounds. I don't know if I should start using it when I never have.
    Quote Originally Posted by mackeeg View Post
    What do you use to chlorinate? If you're using trichlor pucks, then the stabilizer is being added via the pucks. Same goes for powdered shock made of dichlor--the stabilizer is part of the chemical. It would be almost impossible for someone to run an outdoor pool with no stabilizer and keep it algae and bacteria free unless you had a constant addition of chlorine throughout the day.
    In addition, once you add stabilizer, the only way that it is lowered is through splashout, drain/refill, or by letting your pool go green during the winter time, so it's possible that your pool builder added the stabilizer during startup and you still have the residual in the water from that original dose. Have you ever tested your water for CYA?
    Yes use the pucks so Trichloro-s-triazinetrione in the ingredient in there and my shock is sodium dichloro-triazinetrione dihydrate. My CYA is high the pool store said 100
    Yes use the pucks so Trichloro-s-triazinetrione in the ingredient in there and my shock is sodium dichloro-triazinetrione dihydrate. My CYA is high the pool store said 200
    Both of those contain stabilizer, so you have been adding it, even though you didn't realize it. Your stabilizer reading is way, way too high. I'm surprised that you haven't started having problems keeping your water clear--and if you haven't had problems yet you will very shortly. I highly recommend that you drain part of your water and refill it to lower that CYA level.
  1. Is stabilizer necessary?
    By JimK in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-29-2012, 07:48 PM
  2. Stabilizer
    By cooper in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2011, 10:26 PM
  3. Stabilizer
    By Sue225 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-12-2011, 01:22 AM
  4. Stabilizer
    By Calcutta in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-26-2008, 11:31 PM
  5. HTH Stabilizer
    By let_her_flicker in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-20-2006, 07:57 AM
