Results 1 to 10 of 25
Thread: Is stabilizer necessary?
    Virginia
    Default Re: Is stabilizer necessary?
    So not the same Richard, that makes much more sense.
    While you were posting, I was editing my post. Any comments on the info I've added?
    Thanks.
    Go ahead and try it without the Polyquat and just be diligent about keeping up with your chemistry. You can always go back to using it if you decide you need to. I never use any Polyquat, not even when closing my pool. I'm consistent about my chemistry and don't really need it. What I don't have to spend on that, I can use to buy something else like maybe dog food! My 3 golden retrievers go through LOTS of dog food!
    Virginia
    Thanks for the response. When I'm feeling brave and ready to experiment (lol), I'll give it a shot.
    The article you reference is using ORP controllers to monitor the redox potential of the water (and not directly monitoring FC levels) and using a liquid chlorine injection system. First fact, CYA disrupts ORP controllers so systems that use then do not use CYA (or use very reduced levels). Second, his system has a pretty much constant chlorine 'drip" going into the pool. This is how many commercial systems are run out of necessity but it is not necessisarily the best way. I have also worked on a commercial install that used peristaltic dosing pumps for both liquid chlorine and acid for pH control but did not have any electronic control. The 2 pools and two spas at this installation were tested 3 times a day and the dosing pumps adjusted if needed. However, once they were set up they needed very little adjustment to keep everything where it was supposed to be.
    The info he references in the article (including teh one from Kent Williams) are mostly from those with connections to ORP controller manufacturers so it is in their best interest to say that CYA is NOT beneficial because when you use ORP control it is a problem and makes the system malfunction.
    Virginia
    Thanks. I appreciate the clarification.
    Virginia
    Hmmmm......for some reason I can't edit my post. Anyway, if it matters, my Hayward Superpump is 1hp.
    Again, comments and suggestions are most welcome.
  1. Stabilizer
    By cooper in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2011, 09:26 PM
  2. Stabilizer
    By Sue225 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-12-2011, 12:22 AM
  3. Stabilizer
    By Calcutta in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-26-2008, 10:31 PM
  4. Stabilizer
    By mackeeg in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-17-2007, 12:16 PM
  5. HTH Stabilizer
    By let_her_flicker in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-20-2006, 06:57 AM
