Results 1 to 10 of 66
Thread: starting up after winter
    Jun 2011
    Oklahoma
    Default Re: starting up after winter
    GOOD NEWS!!! My CYA reagent came today. I tested my CYA. Filled the tube all the way to the top and the black dot never disappeared. So am I right to assume I have 0-very little CYA??
    20' x 48" Intex round Ultra AGP ~8800 gallons -- Intex krystal clear 635t 1500gph; PF: 13
    Quote Originally Posted by costo View Post
    Yep.
    Jun 2011
    Oklahoma
    I added bleach since I had lost it today again. Also added stabilizer to sock in front of return. When would be the soonest i could check cya. I dont want to waste any tests. I know it usually takes a few days to disolve but Im hoping I can have a good estimate by saturday am before we leave.
    Once you see it disappearing from the sock, you can assume it's in the water-- if you leave your pump running and give the sock an occasional squeeze, it will help dissolve faster. I think you can get it all in by Saturday.
    Last edited by Watermom; 05-17-2012 at 06:24 PM. Reason: change the word "five" to "give"
    Jun 2011
    Oklahoma
    checked my cya...think its between 40-50. I was unable to get the chemicals ordered from amazon so i got some hth tri-chlor tablets and plan to put them in the pool before I leave. I figured with the cya in the pool and the tablets, hopefully i will be good until we get back. planning on running the pump on a timer for about 8 hours at a time. Does this sound right or any other suggestions??
    Probably. You should be fine if you are only going to be gone for a weekend. The worst that could happen is you get a little algae but that would easily be cleaned up. It certainly wouldn't turn into a swamp in a weekend's time! Have a good trip!
    Jun 2011
    Oklahoma
    Thanks for all the help thus far. Ill keep you posted
  1. Starting over
    By RedwingT in forum Intex-type Pool Setup & Operations
    Last Post: 08-02-2012, 12:54 PM
  2. Starting Over
    By shawnw in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-30-2012, 02:33 PM
  3. starting old pool
    By csc138 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-26-2012, 02:44 PM
  4. Starting to get more confused
    By bjdrogo in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-01-2006, 06:21 PM
