Thread: Solar Heating for the pool
    May 2011
    Lake Mills, WI
    Default Re: Solar Heating for the pool
    I built my own solar heater from an old pool pump, 100' of black garden hose attached to plywood painted black, encased under 2 old storm windows I bought for $3 each. Jury is out on whether it is helping or not.
    QUESTION- would the solar cover (somewhat translucent blue bubble wrap) work better if I removed it during the day, and just used it overnight like a blanket? It seems to shade the water and I think the water would warm up better with the sun shining through to the bottom. I think solar cover is a mis-nomer, it is more of an insulated blanket.
    The average high in WI is 75 degrees now and the lows are in the 50s. I'm trying to eek a couple more weeks out of the pool. So far it isn't working, pool is ranging between 66-72. I need 78 to get the kids in it!
    Why can't we post pics? It would be a lot more fun.
    -Shawn
    -8200 gallon 20' x 4' (3.5' really) Intex Ultra Frame. Well water w/high alkalinity.
    -"A" filter cartridge, surface skimmer. I spray the A filter every 2 days when I check the chlorine. I only use bleach (3-6), muriatic acid (to knock down ph & alkalinity), and stabilizer (cya 50).
    Quote Originally Posted by Cords View Post
    Generally taking the cover off during the day and putting it on at night gives you the most heating, but this really depends on the amount of evaporation you get during the day. If your air is very dry or you have a lot of wind (and it's not humid), then your pool may cool off more from evaporation than it would get heated by the sun. As I describe in this thread, around 60% of the energy in sunlight gets absorbed in a typical white plaster pool raising the temperature around 0.7ºF per hour during peak noontime sun if there were no evaporation. However, as I describe in a later post in that thread, 1/4" of evaporation lowers the pool temperature by around 4.9ºF. So which one wins out depends on the evaporation rate. If you are in a humid climate such as Florida, then uncovering the pool during the day is best. If you are in a dry hot climate such as Arizona, then covering the pool would keep it warmer but then again in that desert climate the water is usually too hot and people intentionally keep their pools uncovered to have evaporation help cool them off. If you are in an area with moderate humidity (40-60%) or dry, but you have wind or consistent breezes during the day, then it is probably better to keep the pool covered.
    Note that you can get the best of both worlds by using a clear solar cover since that will let at least some of the light into the pool to heat it. The downside is that you will get the associated chlorine loss since such covers usually let UV through as well.
    May 2011
    Lake Mills, WI
    I would consider it moderate here, and pretty open to breezes. Another downfall of the evaporation is the replacement water is really cold.
    It looks like today & Monday are my last shot, the high on Thursday will be 58. THANK YOU EVERYONE for the successful summer of swimming! The pool was so much easier to take care of, and it looked great.
    BigDave's Avatar
    We have sloar panels on the roof that are valved into the filtration system. The solar contractor who installed them complained a bit that they were too small (all the roof we had available) but I had 1/4" foam installed on the walls and under the floor and we have the solar cover on whenever we're not in the pool. We are very happy so far, we've had pretty bad weather (hurricanes and rainstorms that dumped as much as hurricanes) since the system went in but it's given us several swim days that we wouldn't have had otherwise.
  1. Solar pads for heating pool
    By firemooley in forum --cleanup--
    Last Post: 11-11-2012, 07:11 PM
  2. Heliocol vs. Solar Industries for solar heating
    By KevinSDiego in forum Pool Equipment & Operations
    Last Post: 06-07-2012, 04:22 PM
  3. Solar Heating
    By badutahboy in forum Above-Ground Pool Construction & Repair
    Last Post: 04-08-2007, 12:38 PM
  4. Question about Solar Heating and Distance from Pool............
    By Player101 in forum Pool Equipment & Operations
    Last Post: 07-24-2006, 05:11 PM
  5. Solar Heating
    By AprilRose in forum In-Ground Pool Construction and Repair
    Last Post: 04-22-2006, 02:41 PM
