Results 1 to 10 of 29
Thread: Major Chemistry Problem on open
    May 2011
    Massachusetts
    Default Re: Major Chemistry Problem on open
    Makes sense what you say. Just very frustrated when I look out at pool and the water looks horrible and knowing I have 5 days to get this somewhat presentable. I will continue down this road and cross my fingers. I will test the tap water tomorrow and get back to you all.
    Possibly the high calcium and high acid level might be from the 1" quick dissolving tabs I used for a couple of weeks or possibly from all the rain and pollen we have had here in the northeast. I opened the pool initially to an almost overflowing water level between the snow melt and rain. Either way I'm sure it will clear up sooner or later....hopefully sooner.
    Thanks again for all the help!
    Quote Originally Posted by psciotti View Post
    M. Just very frustrated when I look out at pool and the water looks horrible . . . . .
    I understand the frustration. The danger is, and we see this a LOT, that your frustration will drive you to "JUST DO SOMETHING" expensive and often useless that sometimes even makes things worse! Pool stores live for those moments in pool owner's lives, because they add immensely to the profit margins (and most pool stores aren't doing all that well, thanks to salt systems).
    Regarding the 1" tabs, can you look on the label, and see what the chemical ingredient in those tabs is?
    May 2011
    Massachusetts
    Will do when I get home from work. PH was at around 6 this am after adding 1/2 box borax last night at 10:30. Added another 1/2 box this am and will continue to watch it (water still very cloudy). FC/TC still way up there - that's a mistake I won't make again. Like Watermom said I bleached out my liner a bit and caused a brown stain on my fiberglass steps.
    Would any of these issues have any affect on pool chemistry:
    - My "flooded compressor" issue with my heater - http://www.poolforum.com/pf2/showthr...ter-Compressor - (sorry don't know how to just copy the header link). Could I be leaking some kind of heater chemical?
    - The sand in the sand filter has not been changed since pool was new - going on 9th season
    - old Nature 2 cartridge system (with old cartridge in) still tied into flow?
    Yes.
    + The compressor could add oil to the pool. If have a heater bypass, open it and close the pipes to the heater.
    + Sand doesn't 'wear out' but it can clump up. Most often, however, it gets blown out of the backwash by mismatched pumps, and needs to be replenished. You should check it, after 9 years.
    + With your pH levels, it would add LOTS of copper. Remove the cartridge . . . and don't buy another one.
    May 2011
    Massachusetts
    Just had son check the ph and it's hovering right at 6.8 so I told him to add another 1/2 box borax and check again at 12. At least the ph has stabilized. I am going to by pass the heater since it doesn't work at this point anyway but no bypass I'll have to do some reconnects. As far as the Nature 2 thing it came with the pool and I have never bought another but I will take it out of the system too when I get a chance. How do you add copper and what purpose does it serve? I wish i paid more attention in chemistry class all those years ago!
    + Copper kills algae and causes stains.
    + Low pH dissolves it out of Nature2 cartridges, but if you want to know more use the PF customs search (link in my sig) to search for "Nature2"
    + Chemistry classes would help less than you think -- my older son is graduating honors with a Biology degree and Chem minor -- he LOVED organic chemistry -- and my younger son completed honors high school chem with a 97 on his final, and when I ask them stuff, they are both constantly saying stuff like, "Dad, we didn't study THAT!"
    May 2011
    Massachusetts
    I am pulling my hair out and there is not a lot of that left...all my readings are off my chart or even a best guess level. The pool is completely turquoise color. I do not want to put another thing in this pool until I can get accurate readings. I can't even do basic math anymore it's so upsetting. Since all the colors are off the chart if I use a 1/2 full vial with the Leslie DPD kit do I use the same amount of chem drops and either double (or 1/2 for ph) the readings??
    When I backwash it is a total turquoise discharge.... in my head I'm thinking that maybe my ph is actually sky high and adding the borax is actually making it worse. Right now I turned up the two jets and I am getting small, what appear to be soap type bubbles on the surface.
    All this when I had crystal clear water 3 days ago but a non-existent ph level...... AARRGGHH!
  1. A MAJOR problem
    By SL Dan in forum Dealing with Algae & Slime
    Last Post: 09-01-2011, 05:53 PM
  2. Major Renovation & First Post
    By scavdog in forum In-Ground Pool Construction and Repair
    Last Post: 06-22-2010, 09:58 PM
  3. Must be doing something major wrong
    By karenkr in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-10-2006, 11:55 PM
  4. Newbie with MAJOR problem...
    By MyBlueDog in forum In-Ground Pool Construction and Repair
    Last Post: 06-18-2006, 07:23 PM
