Results 1 to 10 of 15
Thread: Will adding borax to 50ppm kill Mustard algae
    Default Re: Will adding borax to 50ppm kill Mustard algae
    If you would post a full set of test results I could make a better recommendation.
    Waterbear,
    here are my numbers;
    TC-3.0PPM
    FC-3.0PPM
    CC-0.0PPM
    PH-7.8
    TA-125PPM
    CH-175PPM
    STA.-50PPM
    TDS-3600PPM
    SALT-2500PPM
    PHOS-500
    That TDS & PHOS level is kinda high ain't they?
    The water has a salty taste to it.
    What do you recommend?
    oh, by the way, my sig."Man!,this water is cold! is just me trying to be funny.
    Darrell W. -------------------------------------------------------------------
    9,240 Gallon
    15'X 26'above ground
    Using BBB method of chemistry
    Hayward X-Stream 100sq ft cartridge filter
    Hayward 1hp Matrix pump
    Daytona Beach,FL.
    Quote Originally Posted by fuelman View Post
    Waterbear,
    TC-3.0PPM
    FC-3.0PPM
    CC-0.0PPM
    PH-7.8
    TA-125PPM
    CH-175PPM
    STA.-50PPM
    TDS-3600PPM
    SALT-2500PPM
    PHOS-500
    Do you have a SWG? If so, what kind? Salt level of 2500 is below the taste threshold (and too low for most SWGs to operate well, which could be the reason for the Mustard, along with a CYA of only 50 ppm, which is also low for a SWG. Your TDS is only 1100 ppm above your salt so that is your actual TDS (which is a bogus measurement anyway). Phosphates are a non issue in 99% of cases. Mine ore over 3000 ppb!
    Nope, I don't have a SWG.
    I have thought about one but I haven't jumped on board that train.
    I have only ever added a mixture of city water and well water at the first fill, then only city water since to keep the level. Bleach, liquid Chlorine, baking soda, Muriatic acid, Yellow-out, and about 4 doses of all-in one algaecide till I found this site.
    I take it that the salt level is from the bleach?
    The pool has only been up and running since 8/06.
    Thanks for your help
    9,240 Gallon
    Daytona Beach,FL.
    BUMP for answer to above
    9,240 Gallon
    Daytona Beach,FL.
    You know, you could simply take our standard route and raise your FC to shock levels and keep it there until your pool sparkles. Use bleach or Liquid Chorine for that.
    First, lower your pH a bit to 7.2 or 7.3. Chlorine is more effective the lower the pH but too low has other issues.
    Shock your pool with bleach until FC reaches 15ppm and keep it there, checking it twice or 3 times a day. Brush and vacuum your pool everyday.
    Expect it to take a week to 2 weeks to clear. Since you haven't done this, I suggest you do this BEFORE you play with copper or bromine additives. Notice that after you use bromine, you have to use lots and lots of chlorine just to get rid of the "fix"--the bromine. IMHO, it's better to use the bleach to kill the algae.
    My reason for this is we have a tried-and-true method that has worked for thousands of people. If it works, (and it usually does) then it's the easiest and most reliable way to clear your pool. If it doesn't work, then it's appropriate to seek more drastic measures, like the bromine algaecide or addressing the TDS or phosphate levels.
    Once the algae is dead and gone and your pool is sparkling THEN you should add PolyQuat to inhibit further growth. It's sometimes called Mustard Algaecide, or black Algaecide--whatever. Look at the ingredients. The SOLE active ingredient should be Poly....<something long>..... 60%. Whatever they call it, if it's Poly....60%, that's PolyQuat.
    If it were me, I'd raise the pool to 15ppm, add the entire quart, wait 48 hours, then check the FC (it will have dropped ALOT) and then shock again to 15, and consider it done. If it were me.
    You can swim in the water at that level, but wear old bathing suits because they will fade.
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    Borax "Helps" and in my experience it does a great job. Certainly better than all the algecides I've dumped dollars into in the past. I dont need to keep insane levels of chlorine anymore since 50ppm borax.
    But thats all it does. Helps.
    Chlorine, proper PH and CYA levels are what does the heavy lifting and if you don't have those stable at least twice a day all the borax in the world isnt going to keep the algae away.
    My advice is to add the borax to 50ppm and get your Chlorine much much higher and KEEP it there till the algae goes away.
    After that my guess is that your current chlorine levels and borax will prevent the problem from recurring.
    Some people have hobbies.....I have a pool.
    Rock Tavern, NY
    How does one test for Borax & dissolved solids levels? I have the Taylor kit k2006 kit.
  1. Adding Borax to Make your Pool Resistant to Algae
    By PoolDoc in forum Dealing with Algae & Slime
    Last Post: 06-17-2015, 01:37 AM
  2. Using Borax to kill fleas?
    By nicole12 in forum General Interest
    Last Post: 11-08-2007, 10:29 AM
  3. Wanted: Mustard algae or suspected mustard algae
    Last Post: 08-30-2007, 09:40 PM
  4. does shocking kill algae ?
    By lenhorn in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-31-2006, 09:07 PM
