Results 1 to 10 of 15
Thread: Will adding borax to 50ppm kill Mustard algae
    Default Re: Will adding borax to 50ppm kill Mustard algae
    Quote Originally Posted by fuelman View Post
    I am having a hell of a time this year with Mustard algae.
    I think I'm gonna add Borax to 50ppm asper the posts I have searched.
    Will this kill off the algae or must I kill it before I add the Borax?
    How much Borax and how much acid will I need to reach 50ppm?
    I come up with 34 LBS. Borax & 2 GALS., 17oz. of acid.
    Could I try Seaklear Algae Prevention & Remover
    This is chelated copper sulfate. I would not recommend it, although copper is the ONLY algaecide that actually kills algae besides chlorine and bromine. All the others just inhibit it.
    or SeaKlear Yellow Klear
    This is sodium bromide. It would be my first choice but be very careful NOT to overdose. It will take repeated shocking before your FC holds since it temporarily converts the pool into a bromine pool. This is an effective product if your CYA is high and not as effective if it is in normal range. If you have mustard algae then I suspect that you either have higher than average CYA or you are not maintaining your FC.
    and if so, Which? I'm kinda leaning towards the Algae Prevention & Remover.
    Thanks for any help!
    If you would post a full set of test results I could make a better recommendation. Often plain chlorine is all that is needed but with a vinyl pool you will have to bring the levels up fairly high and might suffer some bleaching of the liner.
    The borates, to the best of my knowledge, won't really kill the mustard but are very effective at inhibiting it once it is under control. However, I don't know for sure so it could be a worthwhile experiment. I seem to recall some people on this forum saying last year that borates were the only thing that kept the mustard from returning but I don't know if that is what they used to kill the outbreak.
    Are you SURE that you have mustard and not pollen? They are often confused and I noticed that you have in your sig that your water is cold. Mustard is much more common later in the swim season when the temps are much warmer.
    Waterbear,
    here are my numbers;
    TC-3.0PPM
    FC-3.0PPM
    CC-0.0PPM
    PH-7.8
    TA-125PPM
    CH-175PPM
    STA.-50PPM
    TDS-3600PPM
    SALT-2500PPM
    PHOS-500
    That TDS & PHOS level is kinda high ain't they?
    The water has a salty taste to it.
    What do you recommend?
    oh, by the way, my sig."Man!,this water is cold! is just me trying to be funny.
    Darrell W. -------------------------------------------------------------------
    9,240 Gallon
    15'X 26'above ground
    Using BBB method of chemistry
    Hayward X-Stream 100sq ft cartridge filter
    Hayward 1hp Matrix pump
    Daytona Beach,FL.
    Waterbear,
    TC-3.0PPM
    FC-3.0PPM
    CC-0.0PPM
    PH-7.8
    TA-125PPM
    CH-175PPM
    STA.-50PPM
    TDS-3600PPM
    SALT-2500PPM
    PHOS-500
    Do you have a SWG? If so, what kind? Salt level of 2500 is below the taste threshold (and too low for most SWGs to operate well, which could be the reason for the Mustard, along with a CYA of only 50 ppm, which is also low for a SWG. Your TDS is only 1100 ppm above your salt so that is your actual TDS (which is a bogus measurement anyway). Phosphates are a non issue in 99% of cases. Mine ore over 3000 ppb!
    Nope, I don't have a SWG.
    I have thought about one but I haven't jumped on board that train.
    I have only ever added a mixture of city water and well water at the first fill, then only city water since to keep the level. Bleach, liquid Chlorine, baking soda, Muriatic acid, Yellow-out, and about 4 doses of all-in one algaecide till I found this site.
    I take it that the salt level is from the bleach?
    The pool has only been up and running since 8/06.
    Thanks for your help
    9,240 Gallon
    Daytona Beach,FL.
    BUMP for answer to above
    9,240 Gallon
    Daytona Beach,FL.
    You know, you could simply take our standard route and raise your FC to shock levels and keep it there until your pool sparkles. Use bleach or Liquid Chorine for that.
    First, lower your pH a bit to 7.2 or 7.3. Chlorine is more effective the lower the pH but too low has other issues.
    Shock your pool with bleach until FC reaches 15ppm and keep it there, checking it twice or 3 times a day. Brush and vacuum your pool everyday.
    Expect it to take a week to 2 weeks to clear. Since you haven't done this, I suggest you do this BEFORE you play with copper or bromine additives. Notice that after you use bromine, you have to use lots and lots of chlorine just to get rid of the "fix"--the bromine. IMHO, it's better to use the bleach to kill the algae.
    My reason for this is we have a tried-and-true method that has worked for thousands of people. If it works, (and it usually does) then it's the easiest and most reliable way to clear your pool. If it doesn't work, then it's appropriate to seek more drastic measures, like the bromine algaecide or addressing the TDS or phosphate levels.
    Once the algae is dead and gone and your pool is sparkling THEN you should add PolyQuat to inhibit further growth. It's sometimes called Mustard Algaecide, or black Algaecide--whatever. Look at the ingredients. The SOLE active ingredient should be Poly....<something long>..... 60%. Whatever they call it, if it's Poly....60%, that's PolyQuat.
    If it were me, I'd raise the pool to 15ppm, add the entire quart, wait 48 hours, then check the FC (it will have dropped ALOT) and then shock again to 15, and consider it done. If it were me.
    You can swim in the water at that level, but wear old bathing suits because they will fade.
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    Borax "Helps" and in my experience it does a great job. Certainly better than all the algecides I've dumped dollars into in the past. I dont need to keep insane levels of chlorine anymore since 50ppm borax.
    But thats all it does. Helps.
    Chlorine, proper PH and CYA levels are what does the heavy lifting and if you don't have those stable at least twice a day all the borax in the world isnt going to keep the algae away.
    My advice is to add the borax to 50ppm and get your Chlorine much much higher and KEEP it there till the algae goes away.
    After that my guess is that your current chlorine levels and borax will prevent the problem from recurring.
    Some people have hobbies.....I have a pool.
  1. Adding Borax to Make your Pool Resistant to Algae
    By PoolDoc in forum Dealing with Algae & Slime
    Last Post: 06-17-2015, 12:37 AM
  2. Using Borax to kill fleas?
    By nicole12 in forum General Interest
    Last Post: 11-08-2007, 09:29 AM
  3. Wanted: Mustard algae or suspected mustard algae
    Last Post: 08-30-2007, 08:40 PM
  4. does shocking kill algae ?
    By lenhorn in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-31-2006, 08:07 PM
