Thread: Ok whats floating in my pool?
    Jul 2006
    Default Re: Ok whats floating in my pool?
    the only reason i can see why this happened is,
    faulty test kit!
    I was showing high chlorine levels 3.0+ so i lowered then shut off the chlorine supply.. this went on for two weeks and i still showed a 3.0+ chlorine level.
    time for a new test kit!
    Quote Originally Posted by freddyttt View Post
    3.0 is not a high chlorine level under any circumstances, but if you have any stabilizer at all in your pool, it's not nearly enough to keep your pool clean, especially if you "shut off the chlorine supply". What is your CYA level?
  1. Not sure whats wrong
    By bstevensa in forum Dealing with Algae & Slime
    Last Post: 03-08-2012, 02:35 PM
  2. pool ladder floating
    By SHOVELHEAD in forum Above-Ground Pool Construction & Repair
    Last Post: 05-31-2011, 10:35 PM
  3. Floating Pool Light
    By NullQwerty in forum Pool Equipment & Operations
    Last Post: 05-28-2007, 06:49 PM
  4. Tsp ?? Whats this, Super green pool Help !
    By spankypsl in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-01-2007, 04:09 PM
  5. Whats To Much Bleach?
    By jrv331 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-01-2006, 10:49 AM
