Results 1 to 10 of 13
Thread: Need a special tool!
    Default Re: Need a special tool!
    Jonny,
    any company that doesn't have the parts to correctly do a closing should get the right parts and come back to do it right!!!! I won't bore everyone with the details, but if your 'modified tool' doesn't do the trick, I'll tell you another way (s) to get the *&^&&*^% out
    Kentucky
    I use a cresent wrench adjusted to fit the top. I can usually get enough of an angle to get it loose.
    Another tip: If there's a slot in yours (like mine) a short screwdriver laid inside the slot gives you sufficient torque to loosen it as well, but requires you get in the skimmer up to your shoulder almost to make it work.
    JonnyG is offline Registered+ Thread Analyst JonnyG 0
    Quote Originally Posted by waste View Post
    Jonny,
    Well, this saga continues. I bought an extenable basin wrench which gets a good grip on the plug but it still does not extend out of the skimmer. So I attached a socket to the end of the wrench (removed the short "t" bar) and used a large ratchet to try to unloosen. No luck, I ended up turning the wrench inside the socket. I then pounded on a smaller socker (With a sledge hameer) and tried again - same thing, the wrench warps and loosens inside the socket. It is quite unbeleivable how stuck this plug is. So I ended up calling the pool company and telling them that it was their problem (for putting in the plug). The guy shows up today with a large pair of channel locks needless to say, that doesn't work. Now they will need some one to come out with the "T" wrench that they use for putting these plugs in. Hopefully that will work. Any othere suggestions would be helpful.
    John
    JonnyG (Hunterdon, NJ)
    30,000 Gal IG Shotcrete (Carlton Pools)
    SW Generator
    6ft Sheer Descent
    Jandy equipment (60sf DE filter)
    Zodiac Mars booster pump cleaner
    Teledyne Lars 400,00 Btu heater
    BBB believer
    haze_1956 is offline ** No working email address ** Thread Analyst haze_1956 0
    nj, usa.
    Only thing I can think of is using a long bar to push the wrench jaw against the raised square on the plug so it will grab as you turn.
    I find when I use a basin wrench to loosen a tight nut on a faucet that I often have to squeeze it as I turn. The spring doesn't always apply enough pressure for a good grip.
    The grip seems very strong. In fact it is strong enough that I am able to turn the socket on the end of the wrench without loosing grip on the plug. Pool guys is coming back with a "T" wrench today so lets see if that works.
    Thanks for your help
    John
    SW Generator
    6ft Sheer Descent
    BBB believer
    Pool guy got it with the T-wrench, I have a waterfall now!
    Thank you everyone for the help
    John
    SW Generator
    6ft Sheer Descent
    BBB believer
  1. Pool closing special conditions
    By jonnhid in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-04-2012, 03:29 PM
  2. Can't find 18-year old tool
    By jcg31 in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-28-2011, 10:36 PM
  3. Best Tool I Never Knew Existed!
    By CarlD in forum Pool Equipment & Operations
    Last Post: 07-15-2008, 08:03 AM
  4. Tool for the pump basket plug?
    By hoffmans in forum Above-Ground Pool Construction & Repair
    Last Post: 08-17-2007, 08:07 AM
  5. Special test kit needed for SWCG?
    By lauralou in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-20-2006, 04:18 PM
