Results 1 to 10 of 14
Thread: SWG is not making pH go up
    Default Re: SWG is not making pH go up
    It is partly true that the Borax will buffer the pH so that when you do add acid you will be adding more than if the Borax were not there, but as waterbear points out there are reasons why the total amount of acid needed will be lower. Borax has a double-effect -- it's both a pH buffer AND an algaecide and the latter allows for less chlorine and less chlorine means less SWG on-time and less pressure on making pH rise.
    Your TA will eventually drift downward and the pH will slowly drift upward. Anyway, if you CAN test your TA (and CYA level, if you can, though TA is more important), that would be helpful -- not to solve any problem, since there isn't any, but to help confirm or refute what I believe is going on. I always want to compare the "theory" against real-world behavior.
    Thanks,
    Richard
    Oakland, CA
    Thanks,
    Richard
    Thank you and sorry it took me so long, but I finally got around to measuring the alkalinity and it seems fairly normal at 140 ppm.
    30'x16' (irregular) indoor gunite/plaster pool, 10k gal,
    Autopilot DLG-220 with SC-48 cell, 3/4 HP recirc pump,
    solar panels, heat exchanger from 200 kBTU/hour Viessmann boiler
    Wow, that's actually high (for SWG pools) so that must mean that the Borax is REALLY potent for cutting down the pH rise (and that's what waterbear sees as well). It may also be that the very still air in an indoor pool helps so the aeration may be very, very low. It's interesting, in any case. Thanks a lot for the update!
    Richard
    Oakland, CA
    The pool is almost always covered with a solar blanket (bubble wrap). This is a necessity or the humidity in the room would be unbearable. I suppose this could prevent the hydrogen from being released, and perhaps it forms bubbles under the cover which are readsorbed in time?
    Thanks!
    Luigi
    Maybe. But others with covers still experience a rise, but those are outdoor pools. Maybe your bubble pack is different and as you say it keeps a layer of higher concentration carbon dioxide under it, but the gas does have to go somewhere in any event.
    Another reason you probably don't see as much rise is that as an indoor pool your SWG is running far lower than in an outdoor pool because there is no sunlight to breakdown the chlorine. This is partly why we think the Borates also help -- not only as a pH buffer, but also as an algaecide to lower the production of chlorine. When waterbear added Borates, he found he could lower the output of the SWG.
    Anyway, lots of reasons -- don't know which ones are most important -- but it's good news at any rate. We do know that we have at least two solutions that both work and work even better together -- lower TA and use of Borates. That's good enough for now.
    Richard
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    I've noticed the same thing since my SWCG was fired up. PH seems to be stable for much longer. Where I used to add about 2 cups of muriatic every 3 days, I'm now only adding 1 cup a week.
    Steve,
    You list that you have a "waterfall" in your pool. By any chance, is that waterfall being run less when you turned on your SWG? The waterfall would do a lot of aeration and cause the pH to rise. Over time, the aeration plus acid additions would cause the TA to drop and there would be less and less pH rise over time, but this would take a long time to accomplish. Was there anything else that changed, including chemical additions, the TA level, or the pH? If you turned on your SWG and found the pH to be more stable, then that is indeed out of the ordinary (based on posts from users) and would be useful to figure out.
    Richard
    Guelph, ON, Canada.
    Richard,
    Without trying to hi-jack this thread, I would like clarifcation one of your previous posts. You mentioned that
    "A low TA (adjusted for CYA) could help explain your lack of pH rise"
    Where can I find info on this adjustment and does my Taylor K2005 measurement already include this adjustment.
    Carl Schnurr
    96,000 litre inground, vinyl liner, 1 HP 1speed pump, sand filter, SWG, installed 2005.
  1. Making AG deeper
    By cditty in forum Above-Ground Pool Construction & Repair
    Last Post: 08-15-2012, 12:05 PM
  2. Liner making me NUTS!!
    By dagdouglas in forum In-Ground Pool Construction and Repair
    Last Post: 02-12-2012, 01:41 PM
  3. Making the switch from sand to D.E.
    By Number6 in forum Pool Equipment & Operations
    Last Post: 06-20-2008, 09:47 PM
  4. just making sure...
    By feeshe in forum Dealing with Alkalinity and Calcium
    Last Post: 08-08-2006, 08:25 PM
