Thread: Pool Pilot Info
    jamiestone1 is offline ** No working email address ** jamiestone1 0
    Default Pool Pilot Info
    I am getting ready to install a pool pilot (has not been delivered yet). I would like to know if it comes with a salt tester or do I need to pick up one on my on?
    Ft Lauderdale, Fl
    Default Re: Pool Pilot Info
    The Pool Pilot Digital does not come with salt strips but the Soft Touch does. I would recommend that you take a water sample before adding the salt, add the amount recommended, wait a day for the salt to dissolve and circulate then have the water retested. THEN, if the salt display is different from the test result, calibrate the Digital to match the test result.
    The salt reading should be accurate but it really pays to make sure by doing these tests from the beginning. Once verified (or calibrated), the salt reading should remain accurate from then on.
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
  1. New Member Pool Info
    By schwa in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-26-2012, 02:13 PM
  2. looking for info on getting the metal out of our pool
    By brennac in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-10-2012, 10:00 PM
  3. New Pool info overload
    By noahkid in forum Above-Ground Pool Construction & Repair
    Last Post: 05-03-2011, 02:32 PM
  4. First Pool. just need some info.
    By sjkader in forum In-Ground Pool Construction and Repair
    Last Post: 07-31-2006, 11:51 PM
