First - Hello and Thank you to all of the members who put this great website together! We are pool newbies - and new to a very warm climate, so we are in MEGA learn mode. Up until about 1 week ago, I just assumed all info the pool installers / pool suppliers provide is gospel. Then started reading This Site and Trouble Free Pool just to try to get a balanced view / more information on the MANY products recommended to keep the pool running. Now we are confused and would like some guidance, so that we can get 'into a stride' with maintaining our pool and hopefully never or minimally having to solve any serious problems. Hence this post for answers to questions/advice.
BBB Method - How simple and great of a concept is this! If this had been first explained, I know I wouldn't be feeling so overwhelmed. I definitely would like to start using this method and I am all about KIS - Keeping It Simple - and therefore hopefully cheaper, less maintenance, etc. But believe we need to modify some things, just what I am unsure.
Our Pool: 18000 gallons, IG, gunite, freeform with WetEdge Satin Matrix finish. Chlorine (not SWG) with Nature 2 DuoClear, Jandy Stealth 1.5 pump, Jandy 460 sqft Cartridge Filter, Auto Chlorine Dispenser, Eco Venturi Skimmer.
Location: Missouri City, Texas, just south of Houston. Brand New Pool - Filled pool for first time 1st Aug 2014.
Please advise if anyone requires or suggests more detail on the pool.
Questions/Advice:
1. Reading lots about the Nature2 filters. I gather most people on this forum are not in favor of them. I plan on purchasing Taylor K-2006 test kit. And would like to get my supply water tested (from the mains) for metals to act as a baseline. Recommendations on how/where to test for metals? Or does anyone have experience with the water composition for our zip code 77459? We just 'activated' our 1st 6 mos (and probably last) Nature2 cartridge, as the cartridge supplied by installer was only good for 1st 30 days. I am now wondering if I should remove it (ie panic due to metal contamination/stain risk) or just wait the 6 months and then not put another in. Also, the way our cartridge is connected, means we have to have 'something' in the hole (ie saw off the bottom half of filter & leave the screw cap portion in). Please advise if we should saw off bottom half or just leave in situ after the 6 mos.
Further to the leave in /take out Nature2 discussion, our pool installer recommended Jacks Magic Magenta stuff every 3 months. If we leave in the Nature 2 system, would you recommend this product or another & why? If we take out Nature 2, would we still need to do this, at that frequency, or need another product?
2. Currently using Leslies 3 inch Jumbo Tablets. If I continue using those instead of Bleach (I know different strengths of bleach out there, so I assume using the approx 12% would be best if going down the bleach route), are the drawbacks of using tablets just CYA increasing and cost? Just trying to understand consequences of convenience of tabs once per week vs Bleach daily.
3. Had water tested by pool supplier, then I adjusted TA & pH before installed new Nature2 cartridge. This is summary of the pool supplier testing & mine after some adjustment and before the 'shock' treatment of cal-hypo to activate the cartridge:
FC - 4; TC - 4; CH - 250; CYA - 50; TA - 90ish; pH - 7.3ish; Total Dissolved solids - 600; Phosphates - 200.
Pool Installer (based on using Nature2) recommends TC of 1-3; pH of 7.2-7.4; TA - 80-90; CYA - 30-50; CH - 200-250.
Do the pool installer's ranges seem reasonable or should we be aiming for something different if we take out the Nature2 and go with the BBB method?
What do you all recommend to keep the Phosphates low? I think it is Phosphates which cause the algae start but perhaps I have misunderstood or remembered the different posts incorrectly.
4. Is there any other general advice you can give us for maintaining pool and/or preventing problems which would be more likely to occur in our area?
Many thanks to all of you pool gurus out there!
