They bought it used, WM. They might not have known of the leak when they bought it.
Good job on finding the leaks!!!
Have you seen this post from PoolDoc: http://www.poolforum.com/pf2/showthread.php?17055 . It's a wonderfully detailed description on how to start up an Intex or other small pool.
I did see that post~ awesome info! I am following that plan, however I will be using CYA and bleach instead of dichlor. Should I start adding the CYA as soon as the pool is full? Also, what is the best way to add the borax?
You will need approximately 40 oz of CYA to get within 30 - 50 ppm. Add 20 oz now using the sock method. Wait a week, test CYA, add more as needed.
You can broadcast borax over the surface or you can put it in the skimmer with the pump running or you can dump it in front of a return with the pump running. It dissolves very quickly. Some people get a mild cloudiness when they broadcast it. It doesn't last and isn't anything to worry about.
The pool is almost full!I've been adding bleach following the Super Simple Pool Chemistry. I just tested the Ph, it was 8.2 (or above) According to the Acid demand Test I will need 1/2 pint muriatic acid. The thought of using this acid scares me...is there an alternative chemical I can use to bring my Ph down?
You can use some "pH Down" which is a dry acid.
