Thread: Any suggestions for a Pentair Meteor pump...
    Jun 2012
    Wisconsin
    Default Any suggestions for a Pentair Meteor pump...
    I was changing the sand in my Meteor above ground pump. After I was finished my father went to put the valve back on and couldn't get it to sit right. Long story short, the pipe that connects the laterals to the valve came out. Does anyone know if it is possible to lift the middle assembly out so i can clean it and silicone the pipe back in before replacing it and refilling with sand. Any help would be much appreciated . Thanks.
    Default Re: Any suggestions for a Pentair Meteor pump...
    Quote Originally Posted by YenkoDeuce View Post
    As in, came out of the lateral hub? If you mean, can that be fixed without pulling out all the sand, the answer is No! Here's the manual:
    http://www.pentairpool.com/pdfs/Meteor_sys_OM.pdf
    Sorry.
  1. Pentair pump Problem
    By Huyin in forum In-Ground Pool Construction and Repair
    Last Post: 05-21-2011, 10:01 PM
  2. Pump suggestions
    By duckster in forum Pool Equipment & Operations
    Last Post: 04-11-2011, 12:46 PM
  3. Hiding/Softening pool pump/noise suggestions
    By sahara in forum In-Ground Pool Construction and Repair
    Last Post: 09-09-2007, 05:31 PM
  4. Suggestions on Pump to Filter Connection
    Last Post: 07-16-2006, 10:50 PM
  5. suggestions re: heat pump?
    By farmgirl in forum Pool Equipment & Operations
    Last Post: 05-01-2006, 04:31 PM
