mas985, would you consider above picture fully primed? Or should I really not see any air pockets?
I haven't really noticed the filter pressure change. It is about time to clean up the filter (a cartridge filter) though.
I assume "reducing the suction on the pump" is bad for priming as I think I should go full force when priming? So that's why I was able to achieve better priming when only the main drain was open? BTW, I don't have any valve to control the water flow. I can only either shut off the skimmer using the plastic thing under the skimmer basket or open both main and the skimmer.
I'll add some more water just in case.
So 2000 rpm sounds too low?
Thanks again.
