Results 1 to 10 of 36
Thread: Using the K-2006
    Default Re: Using the K-2006
    You are doing great! TA at 100 is fine. Your CH is high but as long as your water is not cloudy, you're ok. Just don't use any cal-hypo and don't let your TA get high. BTW - The only way to lower CH is to do a partial drain.)
    Jun 2011
    Louisville KY
    Thanks again Watermom – a partial drain, hmm. I have hard water here in Louisville.
    From the water company - Pure Tap®, Louisville Water Company’s tap water, is moderately hard, at 159 mg/L or 9.3 grains of calcium carbonate per gallon.
    So would a partial refill actually help lower my CH level?
    Circa 1980 IG, VL, 36K Gal, DE, Chlorine
  1. Help with K-2006 results
    By Ohio Canoe in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2012, 01:58 PM
  2. Got my new K-2006 testkit...now what?
    By pmoneykitty in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-19-2012, 06:19 PM
  3. First start with K-2006
    By Vtattebury in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-31-2012, 08:31 PM
  4. Defective K-2006 Kit?
    By droweye in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-02-2012, 07:26 AM
  5. K-2006: Might have screwed up.
    By Willjay in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-02-2011, 05:05 PM
