Help with K-2006 results
Just started using my K-2006c test kit last night and here are the results from last night and tonight.
Last night:
PH: 6.8
FC: 4.6
CC: 1.0
CYA:50
TA: 50
Tonight: (after adding 2 cups of Borax this morning; I was guessing at the amount I would need. I read some where to raise Ph it was 1 cup per 10000 gallons?)
PH: 6.8
FC: 1.8
CC: 1.0
CYA:48
TA: 50
I have the pool frog chlorine pack wide open and have added 4 more cups of Borax to try and get the ph up.
28' round 18K gal AG pool; Pool frog chlorinator and mineral pac; Pleatco PWWCT150 cartridge filter; Waterway 1 1/2 HP, two speeds pump; 24/7 May - Sept hrs; HTH 6way.; 4' x 20' Fafco Solar panel ; utility water; PF:6.7
