Results 1 to 10 of 36
Thread: Using the K-2006
    Jun 2011
    Louisville KY
    Default Re: Using the K-2006
    If the pool store guy says add 5 lbs of Tot Alk increaser, DON'T DO IT! And, if you do, yes, use A&H Baking Soda. It's 100% sodium bicarb.
    I NEVER add more than 1 lb of baking soda and I have nearly over 19,000 gallons, near 20k. With your pool, AT MOST add 2 lbs at a time.
    You have 36,000 gallons. So the forumula is: (1,000,000/gallons_in_pool)*(Bleach concentration)*# of gallons of bleach.
    So....(1,000,000/36,000) * .06 * 1 = 1.67. That means one gallon of 6% bleach will add 1.6ppm of free chlorine to your pool. (.06=6%)
    If you use 12.5% then 1 gallon of it will add 3.5ppm of free chlorine to your pool
    Bleach and Liquid Chlorine are the same stuff. Sometimes the pool stores sell it in 6% strength but also as "liquid shock" at 12.5% or in 5 gallon carboys as liquid chlorine, also 12.5%. That's what I use, and the guy I get it from turns it over so fast it usually tests at 14%.
    I understand. The dosage is determined by the water test. The number of gallons to achieve the required dosage is based on the Chlorine percentage. Brilliant!
    Thanks a million – ha ha.
    Now my task is to interpret the test correctly in order to know the dosage.
    Circa 1980 IG, VL, 36K Gal, DE, Chlorine
    Lehigh Valley, PA
    Quote Originally Posted by Manslick View Post
    And to get the dosage, go to the Pool Calculator. You can save this as a file to your HD or a stick and use it offline as well.
    You input the volume, your test results, and your targets (goals) in ppm and it returns to you the amount of product to add. It can be adjusted for type of sanitizer, for instance 5.25% bleach or 10% bleach, and it will calculate for you the effect of adding any number of compounds. A very nifty tool, play with it a little to see what it can do for you.
    With the exception of bleach, where adding too much isn't a crisis, you want to go easy when you adjust chemistry. Most of us add 1/2 to maybe 3/4 of the suggested or calculated amount, wait a while for it to mix in, and test again before adding the rest. It's a lot easier to put in more than it is to take some out
    And I've never used the Pool Calculator. The formula for bleach is easy to use and there's even a short-cut, a rule of thumb so you can do it in your head:
    1 gallon of bleach adds exactly its concentration to 10,000 gallons of water
    So a gallon of 6% adds 6ppm of FC to 10,000 gallons
    A gallon of 12.5% adds 12.5ppm of FC to 10,000 gallons
    Therefore a gallon of 6% only adds 3ppm of FC to 20,000 gallons.
    For everything else I usually start with a quarter of what I think I'll need. I can always add more, much more easily.
    Lehigh Valley, PA
    The Pool Calculator is an excellent tool for any and all additions and/or calculations for pool maintenance. While doing bleach is easy and pretty much idiot proof, calculating baking soda or borax or muriatic acid or CYA isn't quite that simple and the PoolCalc is a huge help.
    Jun 2011
    Louisville KY
    AnnaK thanks for the link to the pool calculator. I love to crunch numbers and that thing looks very cool.
    It's kind of funny to me that after all these years I suddenly want to be proactive instead of reactive to pool maintenance. I was on vacation last week when I opened the pool and with a little extra time on my hands I found this place. Some years I'd get lucky and some years it'd be a nightmare. Now I'm going to fix It before it breaks.
    I was even thinking of catching rain and testing it and if knowing the rainfall amount and the chemistry I could head off potential problems due to rain.
    I'm keeping records for the first time too hoping to spot trends and again head off potential problems.
    We'll see. It feels good to know that when I do get in trouble I have a place to go for help.
    You bet! We'll be right here. Glad you joined us this year!
    Lehigh Valley, PA
    Heh! Two days ago you were intimidated by the testing process and now you want to test rain water. It happens to all of us, that desire to test any and all water sources . Before long, you'll find yourself taking the test kit along when you go to friends' pools, to public pools, to motel pools (and you'll probably not want to get into those . . . ).
    One thing you do want to test is your fill water so you know how much chlorine, TA, and calcium you start out with when you have to top off your water.
    Record keeping is essential. I used to keep a notebook in the pool house; now I record test results and make notes on the iPad. Knowing the 'clean' pressure of your pump/filter is good info to have, right after cleaning the system or backwashing it. You can see trends at a glance and yes, it totally helps you be proactive.
    I'm glad you find the PoolCalc helpful. Next to my WallWhale brush it's my favorite pool tool.
  1. Help with K-2006 results
    By Ohio Canoe in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2012, 01:58 PM
  2. Got my new K-2006 testkit...now what?
    By pmoneykitty in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-19-2012, 06:19 PM
  3. First start with K-2006
    By Vtattebury in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-31-2012, 08:31 PM
  4. Defective K-2006 Kit?
    By droweye in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-02-2012, 07:26 AM
  5. K-2006: Might have screwed up.
    By Willjay in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-02-2011, 05:05 PM
