Results 1 to 10 of 16
Thread: T Cell 15 bad?
    Largo, Florida
    Smile Re: T Cell 15 bad?
    I did the acid wash (and discovered a bunch of debris under the square grid inside the cell tube). Put it all back together and reset, and it seems to have eliminated the check cell lights. Thanks! Still reading low salt @2300ppm (yup,up 100ppm? I did add a cup or two of salt last night, but being that 100lbs is what I'd need, I can't see how that would have made any difference at all.
    The pool store has a rather complicated looking array of beakers and tubes. One of them has a motor that spins a device on the bottom, and they drop a plastic "pill" in while adding chemicals. There's a few other beakers they use, along with a device that looks a bit like a scale with an electric meter on the bottom (I'm guessing this is the salt test by testing conductivity?)
    The salt I bought is "Salinity Fine Grain Pool Salt W/Stain Inhibitor 40 Lb. Bag" so I think I'll put half of that in tonight and see where I end up tomorrow for a salt reading. I think I read too much salt can seriously damage things, is that correct?
    I think I'm on the right track, anyway. Thanks for the help!
    May 2010
    Default Re: T Cell 15 bad?
    If you go to the hardware store, you can probably find a 40 Lb. bag of Morton Pool Salt. On the back of the bag, it will tell you that the 40 Lb bag will raise the the PPM of salt by 480 PPM in 10,000 gallons of water. I would add 40lbs, Give the salt a day or so to dissolve, and check your reading. I would add smaller amounts from a second bag if needed, say half at a time. Bring it up slowly. If you over fill with salt you'll be draining and refilling.
    mas985's Avatar
    Pleasanton, CA
    Sounds like they are doing a TDS test which can have a lot of error as well unless the probe is calibrated often. Personally, I wouldn't trust a pool store test of any kind.
    Mark
    Quote Originally Posted by kelemvor View Post
    Most likely either a Taylor or Bioguard water lab.
    That is a magnetic stirrer and the "pill" is a bar magnet to mix the chemicals. they are actually very useful in water testing, particularly for the calcium hardness, total alkalinity, and salt titration (if testing salt chemcially).
    Sounds like a MyronL salt meter, TDS meter, or their combo salt/TDS unit. MyronL are among the best meters of this type and yes it does measure conductivity. However, they need to be kept calibrated with standard solutions and if this is not done the results are meaningless.
    I if your salt level is too hight your unit will not operate and give you a high salt error. My suggestion is to get a tube of AquaChek Salt test strips. They are actually pretty good, unlike most test strips. See if they test closer to what your readout is or what the store testing is. This should give you some extra confirmation as to whether your cell is going bad or the pool store meter is off calibration.
    FWIW, when cells start dying they often read low on the salt. If you call goldline tech support hotline they will ask you for the amps and volts your cell is putting out and can tell you if it is failing over the phone in many cases. It's worth a shot.
    My suggestion is to try and clean the cell again. You CH at 400, TA at 110 and pH of 7.8 is certainly conducive to scale formation in the cell and I suspect that the unit was not properly maintained, which can affect cell life. Then again, the control unit you replaced could also be defective. You might want to contact whoever did the repair for you.
    Finally, instead on wasting money on special 'pool salt' just use solar salt for water softeners (usually in a blue bag). I am going to make a guess that you live in Florida and your Pool Store is a Pinch a Penny (no, I am not psychic--Salinity is one of their 'house brands'. I actually shop at Pinch a Penny from time to time myself.) I will also guess that the water lab is a Taylor since that is what most Pinch a Pennys use. However, the results are only as good as the person doing the testing and that is often a problem. You really need to get your own test kit. A Taylor -2006 is the one you want (NOT the K-2005). You might have to order it online since most places do not stock it but only carry the less expensive K-2005. The difference is the chlorine testing method. The chlorine test in the K-2006 is far superior and much easier to use than the one in the K-2005!
    Largo, Florida
    Yup, that's the pool store I use. I didn't name the name because I thought I read a rule against that on the TOS when I signed up. I'll pick up some of those test strips, but I already added about 20lb of salt. Even if the store's salt reading is accurate and mine is not, I don't expect 20lb will raise it above the max level the chlorinator says is OK.
    As for the board replacement, I did it myself. I don't really know anything about pools, but I do have a degree in electronics. I'm confident I installed it correctly, but I suppose it's possible it could be defective.
    I need to find some kind of wooden or plastic device to try and scrape the cell as the manual suggests, I just don't have anything non metallic that can get in there, so I've just been using a hose with a jet nozzle, and the acid dip for a few minutes. Also, a few inches of the cell didn't get dipped because the manual warns not to get the part where the cord connects into the acid wash.
    How long should I expect it to take before I start seeing the reading increase some after adding salt? I do have the generator switched "off" but I assume having it plugged in will allow it to refresh the reading?
    Ben and mods, correct me if I am wrong but I do believe that it is ok to mention a store if you are not trying to promote the business but merely saying where you got a product. Even mentioning products can be against the TOS if they are mentioned to promote them but if you are listing the things you put into your pool (which is often necessary to get help with a problem) and not saying "Product X is a miracle that cleared my pool, saved my marriage, cured my dogs cancer, and brought about world peace" then I think you are OK.
    Mod or Ben, please clarify if I am mistaken.
    I know that many of the mods on here have mentioned Leslie's as a source for test kits (and also various online retalers).and Pinch a Penny is the Florida equivalent of a Leslie's store,which we don't seem to have. At least I have never seen one in S. Fl, N. Fl, on the Gulf coast, or on the east coast.
    The are talking about the connector that connects to the control box.
    This webpage might help
    http://www.goldlinecontrols.com/Support/Tips.aspx
    If you want to spend the rediculous amount they charge for the 'cleaning stand' here are instructions for it's use
    http://www.goldlinecontrols.com/Supp...ell_maint2.pdf
    One of our regulars on here, Waste, who is a pool professional said that he uses and expansion plug to do the same. (the plugs used in winterizing if I am not mistaken.) I have never tried this and just use the bucket.
    Do not dispose of the acid in the pool since this will just put the calcium back into the water. I neutralize the acid with some soda ash (doesn't take much) or baking soda (takes quite a bit and foams) and then flush it down the drain once the pH is fairly neutral..
    It's fine as long as you're not selling for the business....see my post #3 in this thread http://www.poolforum.com/pf2/showthread.php?t=10306
    Largo, Florida
    Got the strips. They read about 3800 I'll give the cell another good washing tomorrow (after I come up with some kind of large toothbrush or something for the inside. Unfortunately I can't find the site I thought was selling the cells for 300 bucks so it appears I'm on my way to another $500 purchase unless I get lucky with cleaning this thing.
    Largo, Florida
    Good news for me; I was misreading the strips! I tested 3 times with the strips and consistently get about 2750 for the salt reading, and the cell is reading 2600. Seems close enough for government work to me, do you guys think that's an acceptable range for error there?
    I got an "open" bag of salt from leslies when I went to get the strips (there was one local, after I checked the website. I like the staff at pincher penny better, but I digress) which I got for about 5 bucks. I'm gonna let the pump take a break tonight and put some more in in the morning.
    Oh, one more question. Could the flashing "check cell" condition (reduced efficiency is what the manual says) be caused by the low salt level (also flashing), or does the check cell indicator not get affected by the low salt.
  1. AutoPilot Dig 220 Low Amps-Cell?/Check Clean Cell
    By tthurman in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-01-2014, 08:41 PM
  2. New T-CELL-15 reading lower salt than 7 year old cell
    By sharknj in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-01-2013, 10:00 AM
  3. Help needed in replumbing a new AquaPure style 3 port cell into old 2 port cell space
    By Anonymous European in the US in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 11-27-2012, 01:06 PM
  4. How to read lcd t9 cell
    By bigd4u in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-30-2012, 04:05 PM
  5. SWG Cell.
    By caustik in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-20-2006, 08:17 PM
