Results 1 to 8 of 8
Thread: Need Filter/Pump advice
    Default Re: Need Filter/Pump advice
    Some people, such as Al, have their pump and filter in a pool house. Many people, me included, have mine outside and exposed to the elements. (I do take my pump inside the shed during the winter and drain and cover the filter.) I'm pretty sure that being exposed to the element does contribute to shorter life of the equipment, but Al can tell you for sure.
    One question unrelated to your pump and filter. You say that you chlorinate with tabs in a chlorinator. I assume these are trichlor tabs which are stabilized. Do you monitor your cya level throughout the summer and stop using the tabs if the cya level gets too high?
    Honesdale PA
    I saw something on this forum a long time ago that was a pump cover open at both ends for ventilation. Keeps the rain and snow off. With the pump running the cooling fan will suck in mist from rain and splash. It will cut the life somewhat. Bearings are sealed so it won't get into the bearing itself but will promote rust making servicing that much more difficult. As Lisa said my stuff is in a poolhouse and after almost 13 years everything looks like new. I'm really pushing the memory but I think someone found it at Leslies pool place.
    I dont know what CYA is so I guess I'm not monitoring it. I never stop using the tabs as I start getting algae if I miss a day or two. Ive always used the mini-tabs which are about an inch in diameter--not sure if they are trichlor.
    Your tabs are almost certainly trichlor and they have cya (stabilizer) in them. All pools need some cya in them to keep the chlorine from being lost to the sun too quickly. However, when your cya level gets too high, you have to continue to run higher and higher chlorine levels to keep algae at bay. A lot of people don't know this and they use those pucks for a very long time, unknowingly allowing their cya level to get way too high.
    It would probably be helpful for you to read a lot of the "stickies" at the top of most of the "Pool Water: Treatment, Testing and Problems" section of the forum. A lot of the pool care chemistry basics are explained there. You might want to start a thread in one of those sections and post a current set of water testing results for someone here to look at and maybe head of a potential problem that you may not be aware may be brewing.
  1. Need advice re: heater/pump/filter combo
    By ukdavo in forum Pool Equipment & Operations
    Last Post: 05-28-2013, 06:41 PM
  2. Filter Repair Advice?
    By zooba72 in forum Pool Equipment & Operations
    Last Post: 05-08-2012, 06:44 PM
  3. Buying new filter system, need advice
    By Halfdone in forum Pool Equipment & Operations
    Last Post: 07-16-2011, 10:45 AM
  4. Need advice for correct size AG pump/filter!
    By seadogg in forum Above-Ground Pool Construction & Repair
    Last Post: 05-24-2008, 02:38 AM
  5. Need Pump Advice, Please
    By PopcornGirl in forum Pool Equipment & Operations
    Last Post: 03-20-2007, 11:33 AM
