Results 1 to 10 of 10
Thread: Main Drain - Can"t run pump off MD
    Default Re: Main Drain - Can"t run pump off MD
    Problem was resolved by my pool guy. He said my MD, Spa Skimmer, and Pool skimmer valves were bad. Replaced valves and all is running well.
    Thanks,
    Elle
    May 2010
    Quote Originally Posted by ellry99 View Post
    Thanks,
    Elle
    All at the pad, huh? Sure beats having to dig up concrete!
    Thanks for reporting back -- I'm glad it worked out for you.
    16'x29' free-form 14K gal IG gunite pool; SWCG & sodium hypochlorite 8.25%; Hayward SwimClear C4025 cartridge filter; Hayward SP3202VSP TriStar Variable Speed Pool Pump; custom test kit based on Taylor K-2006C; city; PF:8.6
  1. 7" Main Drain Cover replacement
    By rickrowe in forum In-Ground Pool Construction and Repair
    Last Post: 07-02-2012, 02:59 PM
  2. main drain cover came off
    By robhair1 in forum In-Ground Pool Construction and Repair
    Last Post: 11-16-2007, 01:09 AM
  3. I want suction from skimmers, main drain, AND spa drain - bad idea?
    By joelq in forum Pool Equipment & Operations
    Last Post: 05-03-2007, 08:17 PM
  4. Main Drain
    By bubsmit in forum Pool Equipment & Operations
    Last Post: 05-31-2006, 02:58 PM
  5. Main Drain
    By nicole712 in forum Pool Equipment & Operations
    Last Post: 05-18-2006, 01:56 PM
