Thread: Pump leak?
    Coon Rapids, MN, USA.
    Default Re: Pump leak?
    This is the 5th year of operation so I am guessing it was installed correctly.
    Do they wear out?
    Honesdale PA
    They don't really wear out but sometimes a rib will lift out of the plastic channel and not seal right. They're easy to take apart and check. Put the handle in a mid position, that relieves pressure on the gasket, then take out the 6 bolts. or screws. The whole top assembly lifts out and you'll quickly see what the problem is. Nothing should fly apart. Do mark the top and bottom sections so you get it aligned right when reassembling. Let us know what you find and we'll work it from there. Whenever I switch mine now the pump is off and I press the handle slowly and let any water flow where it wants. Sometimes a rush of water even with the pump off may lift a rib if it isn't glued in solidly.
    Shouldn't the lines be turned off or blocked off, first?
    Honesdale PA
    If the filter is below water level as is usually the case in an above ground, yes, block the lines somehow. I assumed the filter was above water level.
    Quote Originally Posted by Bnelson View Post
    Do they wear out?
    Mine has to be replaced every couple of years--something about the way my system was installed lends it to cracking and crumpling fairly often. Just had to replace it again last week.
  1. pump leak
    By reebok in forum Pool Equipment & Operations
    Last Post: 09-02-2012, 07:56 AM
  2. Pump leak
    By chumpy36 in forum In-Ground Pool Construction and Repair
    Last Post: 05-18-2011, 05:24 AM
  3. leak under pump
    By tggs in forum Pool Equipment & Operations
    Last Post: 04-15-2010, 04:40 AM
  4. leak in new pump?
    By Garvacious in forum Pool Equipment & Operations
    Last Post: 03-26-2009, 08:12 PM
  5. Pump Leak
    By rilesworld in forum In-Ground Pool Construction and Repair
    Last Post: 04-22-2007, 07:36 PM
