Results 1 to 10 of 15
Thread: testing results
    Dec 2005
    Honolulu, Hawaii.
    Default Re: testing results
    My apologies if I misposted. I have not been online for some time so my etiquette is a little rusty. After this post I will create a new thread for any more questions I might have.
    As regards CyA and SWG I had the same experience with the BBB method at 35 CyA.
    I am not sure what misinformation you are referring to? I have always tempered my responses with the caveat that I am clearly nowhere near the level of expertise of the professionals on this forum.
    In any case, thank you for your helpful attempts; however, in future I think it would be all-around a more enlightening experience for everyone if you could reply in a more pleasant tone. We are all just looking for advice, after all.
    Thank you.
    Quote Originally Posted by smallpooldad View Post
    Apples and oranges. You cannot compare a manually chlorinated pool with a SWG any more than you can compare a pool using ORP control to one that is not. IF you did not have the controller and raised the CYA and turned down the output you would find what I say is true.
    For the second question above I am referring to the first two posts you made in this thread.
    I am keeping a very pleasent tone, btw!
  1. Testing results
    By jcwr56 in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-02-2012, 07:05 PM
  2. Advice needed regarding testing results - What next?
    By JuJuBee in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-24-2012, 01:28 AM
  3. CYA Testing Results
    By Simmons99 in forum DPD-FAS based testing
    Last Post: 09-19-2006, 10:48 PM
  4. Program to record testing results?
    By RavenNS in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-23-2006, 09:42 AM
  5. Testing results, need advice
    By mer1844 in forum DPD-FAS based testing
    Last Post: 06-26-2006, 12:07 PM
