Testing results
Morning,
Alright, I've been away from home a couple of days and finally got to retest again. I feel like I'm starting over. However, I did add in the acid and CYA before I left town.
Firstly are there better times to test the water, i.e evening or morning? here are the results.
CL 1
Ph 8.2
ALK - 290
Hardness 410
CYA <30 but improving over last test.
I added more acid and CYA this morning after I tested and will retest in a couple of hours and will post the results.
I'm using the HTH 6 way drop test since Taylors hasn't arrived yet.
Here's the other part of the equation. I was able to get the Taylor salt water test kit locally and the number is reading 7600ppm which is way to high. Intext says 3000ppm is what I should be aiming for. I'm going to drain the pool and refill which I know will now change the numbers up.
Suggestions and thanks!
13' X 39" Metal Framed AGP with an Intex 1600 gph pump, 14" sand filter and SWCG. Have to start somewhere....
