Results 1 to 10 of 20
Thread: Looking for a good sand filter
    Cleveland, OH
    Default Re: Looking for a good sand filter
    I finally got my sand filter piped in last weekend. Its been running for about 2 weeks now and I coulnt be happier. I have yet to put any de in the filter but still planning to do so. When taking apart my cartridge filter I couldnt believe how dirty it was with pollen. My water actually seems clearer. Maybe its just my imagination but thats ok.
    Thanks to everyone.
    Quote Originally Posted by MaxxFusion View Post
    Thanks to everyone.
    I have that filter as well--6 years now. The only things I've done is lube the spider gasket, replace the gauge, and this year, replace the drain cap.
    I haven't been using the DE much as I have been using the skimmer socks and running my Blue Diamond once a week so my water has been super-clear--and I've been lazy about it.
    tonyl is offline Registered+ Thread Analyst tonyl 0
    Indiana
    I've found that a sand filter does a better job filtering if left "a little" dirty; sort of like adding DE which also coats the sand and raises the pressure. I've had good luck by backwashing about 10-15 seconds which removes most of the buildup and leaves me with a few psi over "totally clean". The improvement in clarity as viewed with goggles or with the light on at night is obvious. Not to mention saving some water.
    Hope this helps, Tony
    Quote Originally Posted by tonyl View Post
    Now THIS is a cool idea worth trying! If it doesn't work, just backwash normally! I like it! I'm trying it next backwash!
    What I REALLY like is the fail-safe--I can backwash completely.
  1. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 10:41 PM
  2. Cartridge filter cleaner any good?
    By GCALAHAN in forum Pool Equipment & Operations
    Last Post: 02-29-2008, 04:45 AM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
    Last Post: 05-30-2007, 11:01 PM
  4. suggest a good sand filter/pump model combo for 24' AG
    By ScottS in forum Above-Ground Pool Construction & Repair
    Last Post: 04-01-2007, 12:06 PM
  5. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 12:01 PM
