Results 1 to 10 of 10
Thread: How are my numbers?
    Default Re: How are my numbers?
    Quote Originally Posted by chemicalbalance View Post
    I think you are fine. If you use bleach, it will try to push your alkalinity up over time, so I wouldnt artificially increase the alkalinity with baking soda. Let it stay where its at.
    You're kidding, right? Where did you EVER come up with this? There is nothing in Bleach that is related to Total Alkalinity. Bleach is basically Sodium Hypochlorite in a saline (Sodium Chloride) solution. It doesn't have the requisite Carbon atoms to affect Total Alkalinity.
    Perhaps you have it confused with one of the other B's of B-B-B--Baking Soda, which WILL push T/A up.
    You wouldn't happen to work for a pool store, would you?
    duraleigh Guest
    Carld,
    You are, of course, technically correct but I see no reason for the implied derision in your reply.
    Checking chemicalbalance's other posts, he/she certainly seems to be genuinely interested in helping others and appears to have no agenda....... other than being perhaps a little new to using BBB.
    Mandeville, LA, USA.
    My guess is that chemical balance was thinking of pH. It's a common belief that bleach will raise pH and I think it actually will to a very small extent. Come to think of it, to the degree that it does raise pH, I think it would also raise TA a bit.
    Quote Originally Posted by KurtV View Post
    Actually, not. Bleach IS alkaline, but the acidic reaction of chlorine in the water (ask Chem_Geek if you need an explanation) negates it almost perfectly. So bleach neither raises nor lowers your pH.
    In that line, Di-Chlor is almost perfectly neutral in pH, but because of the chlorine acidic reaction, it lowers pH. Chlorine by gasification also makes the water VERY acidic.
    Actually, not. Bleach IS alkaline, but the acidic reaction of chlorine in the water (ask Chem_Geek if you need an explanation) negates it almost perfectly. So bleach neither raises nor lowers your pH...
    I'm perfectly well aware of Richard's explanations of these processes. That's why I said that bleach will cause pH to rise "to a very small extent". After rereading Richard's explanation (see posts 9, 12, and 14 in particular), I'm still pretty sure that particular statement is accurate. The point of my post, however, was not to argue a fine point about pH and TA. I was simply trying to point out, in a non-confrontational way, what might have been the basis for chemicalbalance's statements.
  1. Help me with My Numbers?
    By mkfmedic in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-07-2007, 02:28 AM
  2. Here's my numbers
    By nicoleh in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-31-2006, 12:32 PM
  3. My numbers...HELP
    By Dafreak in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-26-2006, 05:56 PM
  4. WOW my numbers are off
    By Bowlin in forum Dealing with Alkalinity and Calcium
    Last Post: 05-25-2006, 10:19 PM
  5. Here are my numbers...?
    By crazimom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-17-2006, 12:28 PM
