Results 1 to 10 of 34
Thread: pH keeps creeping up
    Mc Donald, Tennessee, USA.
    Default Re: pH keeps creeping up
    I did a lot of reading over the weekend, that has brought up additional questions.
    Richard, your explanation of saturation with calcium carbonate only being necessary to protect the plaster makes perfect sense. so:
    1) How does one determine when the water is fully saturated?
    2) If CYA contributes 1/3 of its ppm to TA, how much does Borate contribute to TA? (Assuming the Methyl Red/Bromcresol Green indicator--so that we know what the pH endpoint is)
    3) How is Saturation index determined?
    Quote Originally Posted by cnix View Post
    One uses the Langelier Saturation Index (or the equivalent Calcite or Calcium Carbonate Saturation Index). See below for more info.
    Borates contribute a negligible amount to TA. At a pH of 7.5, 50 ppm Borates contributes 5.7 ppm TA so figure an 11% contribution to TA.
    There are many online calculators, some that are good and some that are not, but I believe that Michael Smith's BleachCalc calculates the saturation index. It is a function of pH, TA, CH, TDS and temperature. When the index is near 0, your pool is at saturation for calcium carbonate. Negative numbers indicate risk of dissolving plaster/gunite/grout but only when it's quite negative -- don't even think of worrying until it gets to -0.5. Positive numbers indicate risk of scaling or precipitating calcium carbonate (including cloudiness). Again, don't even think of worrying until it gets to at least +0.5 and realize that most pools don't see any effect until at least +0.7 and some until +1.0 or more.
    For a non-salt pool (i.e. a TDS around 500-1000), an ideal saturation (0.0) occurs at a pH of 7.5, TA of 100, CYA of 40, CH of 300, and temp of 80F. These are the mid-point values for the recommended ranges from NSPI. The pH directly affects the index so a 0.1 change in pH changes the index by 0.1 in the same direction. The TA and CH affect the index logarithmically so a change in adjusted TA (that is, TA reduced by one-third the CYA at a pH of 7.5) or CH by a factor of 10^0.1 = 1.26 changes the index by 0.1 in the same direction. The variation with temperature is small -- index increases by about 0.1 with a 10F temperature increase. The Langelier index, or at least the approximation used by the pool industry, has the index change by -0.08 when going from 525 to 3200 TDS (i.e. from non-salt to salt pool) while my calculations show that calcium carbonate saturation really changes by -0.22 instead. The temperature and especially the TDS calculations in the traditional industry formula are the least accurate portions of that formula. My calculations track the Taylor Watergram so if you have a Taylor K-2006 test kit then you can just use the watergram (using adjusted TA) to get an accurate index.
    Richard
  1. CYA creeping up when only using bleach
    By DesertSwim in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-14-2013, 01:00 PM
  2. pH 7.8, TA 8 - creeping in opposite directions
    By jonno in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-22-2012, 10:17 AM
  3. PH is always creeping up... what to do?
    By deeze in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-08-2007, 12:56 AM
  4. Creeping pH
    By Pool in Carolina Blue in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-04-2006, 05:52 PM
  5. SWG salt keeps creeping up
    By doriec in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-26-2006, 08:06 PM
