Results 1 to 10 of 29
Thread: I'm confused
Threaded View
    topless is offline Registered+ Thread Analyst topless 0
    Jul 2006
    Wichita, KS
    Default I'm confused
    I have tried to search for answers, but my pool test numbers are so different, I'm not sure what to add.
    I just opened the pool Friday, it was green and cloudy so I spent the first 36 hours trying to keep the chlorine high.
    My pool is IG and gunite(?) appr. 20,000 gallons. It's a free-form shape and that's my best guess.
    The first 24 hours I used 68 gallons of bleach. I closed the cover because it rained 1.4" last night. I opened it back up this morning, the water is cloudy, but blueish. I got one of Ben's test kits late last year, so I used it this morning.
    Temp - 69
    FC - .5
    TC - 4
    ph - 6.8
    TA - 250
    CAL - 0
    cya - 0
    Last year I had too much cya, over 150, but I got my test kit too late in the year to use it. I knew my chemistry was screwed up. I also have a foaming problem related to adding the wrong kind of algaecide trying to get rid of a re-occurring issue with mustard algae.
    I added about 2lbs of cya and another gallon of bleach and a lb of borax. How do I add calcium?
  1. confused on cya
    By johnlanciloti in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-30-2011, 08:47 PM
  2. I'm Confused
    By Lisa Tone in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-05-2011, 04:17 PM
  3. Confused about CYA
    By circlenranch in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-01-2006, 08:16 AM
  4. New and Confused
    By ussnewco in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-27-2006, 10:28 AM
  5. I'm a Little Confused ...
    By vinnygnj in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-28-2006, 09:28 PM
