Thread: 2 speed pump low setting and pressure?
    ScottS is offline Registered+ Thread Analyst ScottS 0
    Covington, LA.
    Default Re: 2 speed pump low setting and pressure?
    I recenty set up my 19" Waterway sand filter and piped it with 1.5" PVC. I've got it mated with a 1hp 2 speed pump and on low my pressure is about 2psi. The flow is good and the water is clearer than ever.
    I do have an issue with the multiport valve seating correctly on the filter though. The valve does not seat correctly and will not allow me to tighten the threaded collar all the way. So on high speed the valve pops up some and water comes out between the valve assemble and the tank.
    mjs31 is offline Registered+ Thread Analyst mjs31 0
    Texas
    Quote Originally Posted by ScottS View Post
    Very glad to hear that scott. I have not got the pump wiring fixed yet so I do not have high speed to compare to. I assume I am running in low speed or else I would have a power issue.
  1. If you run a variable-speed pump at half-speed, does the turnover rate double?
    By famousdavis in forum Pool Equipment & Operations
    Last Post: 07-25-2012, 12:22 PM
  2. Hayward Ecostar - What speed / RPM setting should I use? Run time per day?
    By Wraypau in forum Pool Equipment & Operations
    Last Post: 06-05-2012, 10:33 PM
  3. 2 Speed Century Pump Motor is now only 1 speed
    By TelexBill in forum In-Ground Pool Construction and Repair
    Last Post: 10-14-2011, 09:40 PM
  4. 2 speed pump. High speed puts sand in pool?
    By mjs31 in forum Pool Equipment & Operations
    Last Post: 08-23-2007, 05:00 PM
  5. Two-Speed Pumps and Pressure-side Cleaners
    By JimM01 in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-25-2007, 02:01 PM
