Re: Replacing a motor on a pump, and getting the correct size for your pool?
mas985
The SQS1102R is a full rated 1 HP and larger than you need. You need a 1 HP up rated motor (UQS1102R) OR a 3/4 HP full rated motor (SQS1072R) which have an identical 1.25 THP rating.
OK, I think I get it now. I think I'm leaning toward the SQS1072R, as I'm seeing some places say the UQS1102R has been discontinued (looks like HSQ125 is the replacement?) If I went with the SQS1072R, would I need a new impeller and/or diffuser? What about with the UQS1102R or HSQ125?
mas985
Yes, you could just get a single speed and run it shorter to save energy but a two speed will save more over the life of the pump and motor. To control a two speed, you can use a manual switch or a two speed timer. Which option you go with depends on how much money you want to spend up front but no matter what, you will make that money back with energy savings.
Any recommendations on two speed timers, or could something be built from standard electrical parts? I'm a former electrician, so I can wrap my head around the electrical side of things.
26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31% muriatic acid.
