Results 1 to 10 of 48
Thread: Replacing a motor on a pump, and getting the correct size for your pool?
    Jul 2014
    Madison, WI
    Default Re: Replacing a motor on a pump, and getting the correct size for your pool?
    Quote Originally Posted by mas985 View Post
    The SQS1102R is a full rated 1 HP and larger than you need. You need a 1 HP up rated motor (UQS1102R) OR a 3/4 HP full rated motor (SQS1072R) which have an identical 1.25 THP rating.
    OK, I think I get it now. I think I'm leaning toward the SQS1072R, as I'm seeing some places say the UQS1102R has been discontinued (looks like HSQ125 is the replacement?) If I went with the SQS1072R, would I need a new impeller and/or diffuser? What about with the UQS1102R or HSQ125?
    Yes, you could just get a single speed and run it shorter to save energy but a two speed will save more over the life of the pump and motor. To control a two speed, you can use a manual switch or a two speed timer. Which option you go with depends on how much money you want to spend up front but no matter what, you will make that money back with energy savings.
    Any recommendations on two speed timers, or could something be built from standard electrical parts? I'm a former electrician, so I can wrap my head around the electrical side of things.
    26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31% muriatic acid.
    mas985's Avatar
    Pleasanton, CA
    HSQ125 may be an issue because of the back end. I can't guarantee that would fit on the motor support.
    As for the impeller, it depends on the service factor of your current pump motor. If the current service factor is 1.25 or lower, then the impeller is fine. Diffuser would not change either way.
    Timer:
    http://www.amazon.com/Intermatic-T10...W61QF3SM3H6H1T
    http://www.amazon.com/Intermatic-PE1...BXFB6W5PGHAXZ5
    Mark
    Jul 2014
    Madison, WI
    According to the label on the current pump, it's a USQ1102 equivalent, with a SF of 1.25.
    Thanks for all the help! I think I'm going to get or order the SQS1072 after checking with my local pool warehouse.
    Jul 2014
    Madison, WI
    Am I understanding this right... could this be used to program when the pump is on while also putting a timer on when the pump is switched to a certain speed? Would the main on/off timer feed the switch that determines when the pump is on full speed? That's the sort of thing I'd find handy to have, with manual overrides (if possible.)
    Jul 2014
    Madison, WI
    Never mind the previous post. I found the wiring diagram on how it works.
  1. Replacing a Dead Pump Motor
    By Peabody in forum Pool Equipment & Operations
    Last Post: 06-07-2012, 12:46 AM
  2. Replacing pump motor
    By bbsmith in forum Pool Equipment & Operations
    Last Post: 04-27-2012, 11:51 AM
  3. Correct Pump Size for Filter
    By RobDHW in forum Pool Equipment & Operations
    Last Post: 05-18-2011, 11:27 AM
  4. Need advice for correct size AG pump/filter!
    By seadogg in forum Above-Ground Pool Construction & Repair
    Last Post: 05-24-2008, 03:38 AM
  5. Replacing Pump Motor Only
    By let_her_flicker in forum Pool Equipment & Operations
    Last Post: 06-06-2007, 10:43 AM
