Thread: Replace incadescent with LED
    Largo, Florida
    Default Re: Replace incadescent with LED
    You have to replace the whole assembly along with the wiring through the conduit. On the bright side it's easier to do than you'd think and LED's look much better since they can be white where incandescent are yellow. Your pool will look bright blue at night instead of green.
    Basically you cut the old light cable off, tie the new cable onto the old one and use the old cable to pull the new one up through the conduit. If you ordered the right voltage (12v or 120v) light it should just be a matter of screwing things in after that. An hour, maybe much less.
    Sep 2014
    Tucson, AZ
    Quote Originally Posted by kelemvor View Post
    Thanks. That makes a lot of sense....there may be an DIY LED upgrade in my future....
    Mar 2014
    Tennessee
    I ended up putting in a 120 watt equivalent LED flood lamp and its bright enough to light up my pool. Happy so far!
    Jul 2013
    Northern Illinois
    Thanks for the update!
  1. Trying to replace o ring
    By Vykke50 in forum Pool Equipment & Operations
    Last Post: 07-20-2011, 09:04 PM
  2. need to replace return eye
    By rnjng in forum In-Ground Pool Construction and Repair
    Last Post: 06-02-2008, 08:03 PM
  3. When to replace FAS-DPD #1
    By tbatti in forum DPD-FAS based testing
    Last Post: 09-04-2006, 11:50 AM
  4. How often do you replace your filter?
    By bkny1055 in forum Pool Equipment & Operations
    Last Post: 08-12-2006, 02:24 PM
  5. Need to replace pump
    By sasgharian in forum Pool Equipment & Operations
    Last Post: 04-10-2006, 07:58 PM
