Morning Sunny! I'm used to doing things manually from my old pool so I'm not so sure about the acid pump. I'm trying not to add too much in that will need maintenance...but will keep some conveniences.Best of both worlds. The SWCG is to make sure we're getting chlorine in the pool. I sometimes work some pretty long hours including weekends and our vacations can last about 2 weeks. That is the only reason we're getting it.
The decision to go not go with the Intellichlor was based on what I've read, and even the builder said it wasn't very reliable and didn't mind the switch. Honest man. There have been some good reviews on the IC40, like yours, but there seemed to be more bad.
We are still getting the 3 year warranty as you mentioned since our pumps, heater, and filter will be from Pentair. Our setup is actually very close to yours, Intelliflo VS, (smaller pump for the waterfeature but I'm still waking up so I can't think off the top of my head), MasterTemp Heater, and TR-140 sand filter. Also, the EasyTouch.
Do you have pics posted of your pool? I'd love to take a look.
I would also add that you consider an acid pump, like the IntelliPH from Pentair, as part of your equipment pad. SWCG pools tend to have constantly rising pH which, especially in the beginning, means very frequent acid additions. An acid pump will also add to your "peace of mind / ease of use" factor.
