Results 1 to 10 of 109
Thread: Salt Water Chlorine Generator for New Pool Build
    Sep 2014
    Tucson, AZ
    Default Re: Salt Water Chlorine Generator for New Pool Build
    Quote Originally Posted by Toybuilder View Post
    It sounds a lot like the RS unit we had. I just looked at the bid and it doesn't say how many channels, but since we have more than 4 things to control I'm assuming it's 8. Will have to make sure, though. It also looks like we're getting the wall mounted controller AND the wireless. Will have to confirm that too. Do you happen to know the range of the wireless controller? I just looked thru the brochure and I didn't see anything.
    In attached photo I'm standing at my side door (kitchen) and I'm ~ 40ft or so to the wireless antenna (green circle/blue arrow). The equipment pad is around the corner (red arrow) behind the casita.
    I think my PB said it can do 100ft easy but from inside the house it can get dodgy if you have walls with lots of pipes and wiring.
    Parker, CO
    Quote Originally Posted by SunnyOptimism View Post
    I don't think we'll need the booster. The wireless controller will only be used when we're outside using the spa, and we'll be well within 100ft. But, good to know the antenna exists. It's not even listed on their brochure.
    Sep 2014
    Tucson, AZ
    Yeah, like the IntelliWand and half a dozen other things that Pentair never tells you about. My PB is a Pentair reseller for this area and he knew all the inside scoop on the various Pentair gizmos. It's not hidden per se, it's just Pentair, like any major manufacturer, wants to steer the consumer as much as possible through their distribution channel. So for the casual buyer, you really have to dig to get the full picture.
    Parker, CO
    Thanks for all your info on the EasyTouch. I feel a bit more at ease with it since it seems similar to the RS. May hit you up again once I get to programming.
    Parker, CO
    Well, I'm checking out until after dinner. You guys are killing me with all this talk about pizzas and hotdogs. Thank goodness dinner will be early tonight.
    Yeah, I was thinking about it too, watching the NYG/Dallas game. Then came a commercial for Papa John's pizza and I completely lost my appetite for pizza....
    Sep 2014
    Tucson, AZ
    Anytime. If the Pool Forum god (aka, @PoolDoc) decides to enable private messaging, then we could take a lot of the incidental questions off the thread. Until then, you'll just have to post. I think my profile allows for vCard access but I'm not sure....
    Parker, CO
    Ok, feel much better now. My belly is full. But those pizzas still sound good.
    To update you, I emailed Poolsean privately and discussed the benefits of the AutoPilot vs the AquaRite. Wow, there's a lot to sort through. Obviously it leaned heavily on the AutoPilot. I'm going to review with the builder to help us decide which would be the best for our situation. However, my big concern is still the price.
    Jul 2013
    Northern Illinois
    Good. I guess both Carl and I contacted Sean off-forum. He will tell you the truth so you can decide. Hey, SO, it's slow season. We won't get lost in a side-tracked thread here! Enjoying Dungeness Crab ravioli and some red as I write!
  1. Problems with SWCG (salt water chlorine generator) on inground pool
    By jdubose in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-22-2014, 09:16 AM
  2. Replies: 8
    Last Post: 04-09-2012, 04:37 PM
  3. Salt water chlorine generator research
    By sevver in forum Pool Equipment & Operations
    Last Post: 07-23-2006, 07:05 PM
  4. Salt Water Chlorine Generator
    By blonde_b_tan in forum Pool Equipment & Operations
    Last Post: 06-03-2006, 01:34 PM
