Results 1 to 10 of 109
Thread: Salt Water Chlorine Generator for New Pool Build
    Default Re: Salt Water Chlorine Generator for New Pool Build
    Oh, yeah. I get about a foot of ice, minimum, on top of my pool water. I drain below my skimmer and the return ports for the winter.
    Parker, CO
    The reason I ask is that we requested that our spa be usable year round. I'm just not sure how that's going to be possible with the winters we have. We've had sprinkler pipes crack in early spring. We're planning on enclosing the equipment with a shed or something but I'm not sure that will even work. Hopefully the builder has done this before and I'm just worrying over nothing. Do you know of anyone that has the spa open year round with freezing temps?
    At any rate, I did a little more digging on the AutoPilot, and from what I can figure out, a power supply will be necessary, what they’re calling the Pool Pilot Digital or the Soft Touch along with the Manifold. For our setup, the cost will be about $1400 to $1500 (lowest prices I could find). Wee bit out of my league so I think I’m going to go with the Aqua Rite.
    Thank you, and JimK, again for all your help. Couple of days and 2 biggies off my list.
    On to the next inquiry. Any suggestions on robotic cleaners?
    Ft Lauderdale, Fl
    Toy, what size pool are you building? Where in Colorado? If we don't have an authorized dealer in your area, I can also work with your builder to get it installed.
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
    Ft Lauderdale, Fl
    Just re-read this string. Keep in mind that the output of the T15 is equivalent to the AutoPilot RC42 cell. My website shows the MSRP. Don't use that as a comparison for pricing.
    If you're around the Denver area, Monarch Pools is an authorized dealer.
    Sean Assam
    Parker, CO
    Quote Originally Posted by Poolsean View Post
    Howdy PoolSean,
    Glad to see you’re still around. To start off, our pool will be about 16k gallons with and attached spa with about 850 gallons, and we’re in the Denver metro area. We’ve contacted John at Monarch already so we are familiar with each other.
    I’ve pretty much pulled the trigger on the AquaRite but I can still change my mind if you can convince me that Autopilot is better. At this moment, we just need a chlorine generator to give us piece of mind. The pump time will be controlled by the Pentair EasyTouch . The only thing that’s not covered is the salt level but I’m sure I can grab some kind of specific gravity meter to test that or bring a water sample into a pool store.
    The prices I found for what the Pool Pilot Digital and the Manifold equivalent to the the AquaRite, and were not from the Autopilot website. That would have put us closer to $2000. Even Amazon would have been more.
    Please tell me the difference between Hayward and AutoPilot. Our first pool didn’t have a SWCG so this is all new.
    Virginia
    Quote Originally Posted by Toybuilder View Post
    Howdy PoolSean,
    These work well for testing salt level;
    http://www.amazon.com/Aquachek-White...lt+test+strips
    Sep 2014
    Tucson, AZ
    Quote Originally Posted by JimK View Post
    I have both test strips and Taylor K-1766 chloride test drops. Taylor drops are more accurate BUT here's the deal - don't get too crazy trying to exactly measure your salt levels, it'll only drive you nuts. Once your PB loads the salt in your pool at startup and assuming the SWCG cell is happy, you only need to test salt levels maybe twice per swim season or after a major (>10%) water exchange. Too many SWG owners get way too crazy trying to figure out their salt levels to the last signigicant digit. The available tests are, at best, +\- 200ppm accurate. If your salt cell says it's happy, then you're good. The whole point of making SWCG practical is for the process to be insensitive to salt concentration over a wide range or else it would be too much of a hassle for the user.
    Just my $0.02 opinion.
    Sep 2014
    Tucson, AZ
    Smile Re: Salt Water Chlorine Generator for New Pool Build
    I live in Tucson, a far warmer climate than yours, so I'll put in my two cent opinion on spa's in winter time - I don't think your request to have a usable spa year-round is feasible in your geographic area. I'm not saying that it can't be done (people use hot tubs in freezing climates all the time) but it depends A LOT on the location of your pool/spa relative to your house as well as how you plan to heat it (gas, electric, etc) and how you're going to winterize your pool relative to the spa.
    As far as comfort goes, when the air temp hits the low 40's, going into and out of a heated spa can be difficult. Even if you are fully submerged up to your chin, your head is going to lose a lot of heat and it will be uncomfortable. We have freezing temps down here in the desert and I rarely want to go out to the spa once the air temps are below 55F...it's just more work/effort than I care to expend.
    This brings up the other point - energy to heat a spa. 1 BTU is the energy it takes to heat 1 pound of water 1 deg F (water is 8.4 lbs/gallon). I have a 400,000 BTU/hr gas heater and an attached spa of roughly the same volume as yours. In winter, to go from 40F water temps up to 90F (if that's even possible given the surface heat loss) would take 336,000 of BTU's of gas, or about 3.36 Therms (gas cost is typically measured in Therms, 1 therm = 100,000 BTU). Given local gas costs here, that's probably about $10/hr to run the spa. That doesn't even factor in the electrical energy costs of running the pumps, so if you plan to use your spa a lot in the winter, it can cost you quite a bit of money
    Finally, winterization - If your spa and pool are connected on the same pump system, it will be hard to winterize your pool (close it) and keep your spa open. You'll need a chlorination method for your spa that doesn't rely on the SWCG because most cells have a cold-water cut off feature and won't run when the water temp is below 50F. Also, most automated pump control systems have an "anti-freeze" setting where the pumps run once the air temp drops close to freezing (my system is set to 38F air temp to kick on the anti-freeze option). Again, this complexity needs to be factored into winterization.
    In your area, I probably would have opted for a pool with a separate hot tub or, with a pool/spa combo, then I would just winterize everything. My pool/spa stays running/open all year round because we rarely ever get any surface freezing here and day time temps in southern AZ can go into the 60's easily making winter algae a possibility.
    Again, just my opinion. Folks in your area may do pool/spa combos a lot and, hopefully, your PB knows what he's doing....
    Parker, CO
    Quote Originally Posted by SunnyOptimism View Post
    Thanks for the post SunnyOptimism. There have been many concerns that have crossed our minds…my mind, and I’m fairly confident that our builder knows what he’s doing. He’s been building pools here for almost 30 years. We’ve been pretty careful to not pick a builder that was just a yes man and promised us the world. He’s proven himself several times already with suggestions/recommendations.
    Prior to moving to Colorado, we lived in a dessert climate in southern California. Our temperature extremes went from 115 in the summer to sometimes 30’s in the winter. Not like they are here in Colorado, but we had some wild swings none the less. We jumped in the spa in those (good ol days) without issues. I understand the discomfort you’ve described but we love our relaxing spa and have not been bothered by the cold temps.
    Right now, my main concern is more about possible damage to piping. Pipes freeze and break and I don’t want that to happen. I have sent a message to our builder to confirm that this will not be an issue.
    I really appreciate the input and I know where you’re coming from. Hopefully, all will work out for the best.
    Jul 2013
    Northern Illinois
    I asked one of our hydraulics gurus to take a look at your thread. Hopefully he can help! He knows a ton.
  1. Problems with SWCG (salt water chlorine generator) on inground pool
    By jdubose in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-22-2014, 09:16 AM
  2. Replies: 8
    Last Post: 04-09-2012, 04:37 PM
  3. Salt water chlorine generator research
    By sevver in forum Pool Equipment & Operations
    Last Post: 07-23-2006, 07:05 PM
  4. Salt Water Chlorine Generator
    By blonde_b_tan in forum Pool Equipment & Operations
    Last Post: 06-03-2006, 01:34 PM
