Re: Salt Water Chlorine Generator for New Pool Build
JimK
I have both test strips and Taylor K-1766 chloride test drops. Taylor drops are more accurate BUT here's the deal - don't get too crazy trying to exactly measure your salt levels, it'll only drive you nuts. Once your PB loads the salt in your pool at startup and assuming the SWCG cell is happy, you only need to test salt levels maybe twice per swim season or after a major (>10%) water exchange. Too many SWG owners get way too crazy trying to figure out their salt levels to the last signigicant digit. The available tests are, at best, +\- 200ppm accurate. If your salt cell says it's happy, then you're good. The whole point of making SWCG practical is for the process to be insensitive to salt concentration over a wide range or else it would be too much of a hassle for the user.
Just my $0.02 opinion.
