Results 1 to 10 of 17
Thread: Murky algae pool
    Jul 2014
    NC
    Default Re: Murky algae pool
    I will have to get my son to test the pool this evening (working out of town until tomorrow) and add the bleach/possible borax. This morning the color was a pale light green- getting closer! (It has not been this light with any of the shock etc I was using before. I can make out the second step now. The first step the water looks clear except for what I am suspecting is mustard algae (or dead algae but it has a brown color to it). When I vacuum or use the leaf rake along the bottom of the pool, you can see a cloud form in the water.
    Jan
    18x36 IG vinyl, Hayward Sand Filter S220T, 1hp pump.
    Quote Originally Posted by janbogus View Post
    Sounds like mustard algae.
    Jul 2014
    NC
    Levels this evening are chlorine 3.4 and pH 7.2. I figure I've had a couple different types of algae. Will have to read up on the site on how to get rid of the mustard algae as the green disappears.
    Jul 2014
    NC
    Received my Taylor 6200 kit today. Took new readings and if I did the analysis correctly, I got the following levels:
    FE: 1.2, CC: 2.2 Ph: 7.0, Alk: 100, CYA: 42, and CAL: >1100.
    I added two more gallons of bleach. I did not add the borax the other day because the levels had risen. Looks like I need to add it now. The pool is a hazy, cloudy blue. I can make out the jets and the third step in the shallow end. When I started to vacuum to waste tonight, the billowing clouds returned. So it looks like the mustard algae is still there.
    What would you suggest next?
    Two questions:
    1. Are you sure your CH (calcium hardness) is 1,100?
    That's 110 drops of reagent! If you haven't already, watch the Taylor videos: http://pool9.net/tk-guide/ and http://pool9.net/tk-interfere/
    Also, please test the pH, TA and CH of the water you filled your pool with -- presumably your house water, but upstream of any softener, etc.
    2. Can you explain the sequence of the "billowing clouds"? Where were these clouds billowing from?
    I don't understand, since vacuuming to waste should have ZERO effect on your pool water, since the discharge water is going out the backwash line.
    Jul 2014
    NC
    I did not test my house water. I did watch the Taylor video and also checked out the website that poolmom recommended.
    My pool water is still a cloudy blue (i.e. can't see the bottom of the pool). The "billowing clouds" are brown and come from the bottom of the pool when I vacuum or brush still but not as bad as they were. I do believe I still have mustard algae or else it is dead algae and that's causing the "clouds". (Please note, on the other side of my property, probably less than 50-100 yards from the pool is a drainage ditch for run off water from the city.) It has rained a couple of heavy downpours over the past week and I did add more borax and a couple gallons of bleach throughout the week. I read the levels yesterday morning and again this morning. Yesterday after reading the levels, I put in one box of borax, half a box at a time. Last night I added two gallons of bleach.
    Here are the levels over the last couple of days.
    7/19: FC: 5 CC: 4.0 PH: 7.0 TA: 120 CH: 375 CYA:80
    7/20: FC: 8 CC: 2.5 PH: >8.0 (purplish color) TA: 100 CH: 290 CYA: 90
    So the combined chlorine is dropping.
    I am going to look over the instructions again. Do I go ahead and use a floculant to drop everything to the ground so I can see what I have left in the pool? When I use the leaf net I don't get anything and when I vacuum to waste I am not getting much debris from the pool floor in the skimmer basket.
    If your numbers are accurate, then your chlorine is no where high enough to kill algae. With a CYA of 90 (and by the way, you do NOT need to test this daily as it won't change that quickly and will just waste testing reagents), your shock level is 20ppm. But, if you truly do have mustard algae, your shock level may need to be even higher. But, since you haven't been maintaining consistent readings of 20, I'd try that first before deciding to go higher. Again, the chart with the CYA/Chlorine connection is here:> http://pool9.net/cl-cya/
    Keep the chlorine at shock level until you meet these 3 criteria:
    1) You lose no more than 1ppm of FC from sundown one evening to within an hour of sunrise the next morning
    2) You have no greater than 0.5ppm of CC
    3) Your water is clear and no patches or spots of algae anywhere
    At that point, we recommend keep the chlorine high for at least one additional day and then let it drift down but never let it drop below the minimum from the chart which is based on your CYA reading.
    I would NOT use a floc at this time. There is no reason to. I think your problem is that you haven't killed the algae because of inadequate chlorine levels.
  1. Murky pool, tadpoles, and an inexperienced owner!
    By JV1980 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-29-2014, 12:50 PM
  2. Ugh! Still murky after a couple weeks
    By mikora7 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-04-2012, 09:55 PM
  3. murky green water
    By purplegirl in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-26-2012, 05:49 PM
  4. Help - brown stinky dark murky pool
    By pairadocs in forum Dealing with Algae & Slime
    Last Post: 05-14-2006, 09:52 PM
