Results 1 to 10 of 17
Thread: Skimmer not catching debris floating on surface
    Jun 2014
    Texas
    Default Re: Debris floating on surface
    My pool is rectangular laid out east and west.
    The skimmer is on the west end.
    If the wind shadow caused north winds they would blow across the pool and be neutral to the skimmer.
    I guess I could fashion some kind of wind sock and see if there is a persistent wind blowing against the skimmer.
    If there is I don't know much I can do about it, but at least I can stop wasting time trying to fix it by adjusting my jets.
    I should have added that there is a 3' rock wall on the north edge of the pool, which should block any northerly ground winds.
    I haven't noticed debris collecting on any side of the pool as though blown and kept there by wind.
    It seems to just float around randomly and not be pushed toward the skimmer.
    BTW- I appreciate your trying to help me with this.
    IG pool
    Quote Originally Posted by WillB View Post
    If that's the case, then it may not be wind. You can always check by throwing some dry leaves on the pool, and then watching.
    But . . . if it is random movement, then you may be able to at least partially solve the problem by aligning the jets to create a rotary current. If you can't swivel your eyeballs enough, you can purchase these:
    Hayward SP1419A 1-1/2-Inch MIP Inlet Fitting
    Jun 2014
    Texas
    I just ordered three of them. I'll probably be trying them next weekend.
    Thank you.
    IG pool
    Let me know how it goes, please.
    Jun 2014
    Texas
    I'll do it
    IG pool
    Jun 2014
    Texas
    Finally made it back.
    I ordered and installed the three Hydrasweep jets. I had to remove two of them because they raised my pump pressure about 10 lbs.
    I can't tell any real change using the one.
    I'm just going to have to experiment with what I have and try to push the debris toward the skimmer.
    Thanks again for your interest.
    IG pool
    I'd take the other two and -- carefully -- use a Dremel tool, die grinder, wood rasp, or small coarse file to open the slot, till you achieve sufficient flow.
    To stabilize the work, you'll probably need to screw the jet into a 1.5" FIP adapter on a piece of 1.5" PVC pipe.
    Jun 2014
    Texas
    I have rasps. I'll make that a weekend project.
    IG pool
  1. white substance floating on pools surface
    By erika1026 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-20-2014, 04:37 PM
  2. Foamy chemical floating on surface...
    By finks213 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-19-2013, 06:57 PM
  3. Oil slick looking surface inside skimmer
    By mneal in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-28-2006, 01:02 PM
  4. Too Much floating debris overloading skimmer.
    By jenpen400 in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-26-2006, 07:42 PM
